20 Most Recent AcerView F51 15 in. Flat Panel LCD Monitor Questions & Answers
Try connecting the wires properly. try changing the VGA cable. i had the same problem my screen goes black some times and pink i changed the VGA cable it was absolutely fine!!!
What is VGA cable
VGA Cables Adapters Converters and Devices C2G
visit a computer mechanic for further trobleshooting
AcerView F51 15... | Answered on Feb 20, 2019
Have you checked the settings in your screen-saver and power options in the display control panel?
AcerView F51 15... | Answered on Dec 24, 2007
You can use a DVD copy program like Nero if there is one on your computer.
Nero checks to make sure that you DVD isn't copy protected before it copies it. If it is you won't be able to copy it.
Windows XP or Vista does't provide DVD copy software built into Windows.
Acer Computers &... | Answered on Mar 20, 2019
It's possible to use USB Dongle to have a Bluetooth connectivity. They are available for under $ 10 and plug & play on Windows 10.
If you are in the bios then it's probable that the cmos battery is flat. Look at the bios date. If it has gone back to default and not current date then change the date to the current.
boot order is normally Hdd, cd rom, usb and network last.
put into that order. If your hdd is no good then the machine will look for a usable drive. If you have a windows setup disk it will boot from that into windows setup.
press f10 save settings and exit. The machine will boot to what ever works first. After successful boot, then turn off and reboot again if it boots into the bios then check the date again. If it has gone back then you need a new battery. They only a pound or so..
Acer Computers &... | Answered on Mar 19, 2019
check the memory ram
If the computer is on, check to see if there is more that one input for the monitor. Monitors can have multiple inputs. There should be a way to access an on screen menu from the buttons on the monitor. Try different inputs.
Acer Computers &... | Answered on Mar 18, 2019
Vergeef me, ik vertaal naar / van het Engels. Is er een LED-lampje op de voeding? Misschien wilt u eerst een nieuwe voeding proberen.
"Forgive me I'm translating to/from English- Is there an LED light on the power supply? You may want to try a new power supply first."
Acer Computers &... | Answered on Mar 14, 2019
Cheers!!
Please enter the model detail and download the manuals from this website Download Drivers and Manuals Acer Official Site
Acer Computers &... | Answered on Mar 13, 2019
Your hard drive may have quit(died). No good solution other than replace the hard drive. Do you have a restore disk for you computer, to use after replacign the HD?
Here is the website for Acer PC
Acer Computers &... | Answered on Mar 09, 2019
NEVER KNEW LAPTOPS COULD USE SIM CARDS AS THEY ARE MAINLY FOR CELL PHONES FROM THE SERVICE PROVIDERS
HOLD THE F2 BUTTON DOWN WHEN YOU POWER IT UP . REST IT TO DEFAULT IN THE BIOS
Acer Computers &... | Answered on Mar 07, 2019
  1. Unplug AC power adapter.
  2. Locate the battery reset pinhole on the bottom of the computer.
  3. Insert a small paperclip in the battery reset pinhole. Hold the reset button for 4 seconds.
  4. Let the computer sit for 5 minutes with no power.
  5. Connect the AC adapter and power on the system.
Acer Computers &... | Answered on Mar 04, 2019
v193hql
this monitor is 2012 built so is LED monitor, good. that.
no photo of which of 3 boards inside or IC top words.
is the IC top sanded clean.
many chips are custom chips (ASIC) or on contract from ACER to maker. (a secret))
how many pins on chip, just 3 or 25+
no photos of chips is a no joy event;
we cant see them in a text box unless added by clicking
photos button below. sizes 1024 max. jpg , gif best.
AcerView F51 15 in. Flat Panel LCD Monitor Logo
Popular Tags
3 questions posted
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
View Most Popular
  • Acer Computers & Internet
Most Popular Question
acer al1914 monitor goes black
  • Computers & Internet
