20 Most Recent
AOC CT720G 17" CRT Monitor Questions & Answers
Which components need to be replaced when horizontal lines appear?
What horizontal lines do you mean? I can think of several.
- You could have a line of dead pixels on your monitor, this would probably be caused by wear and tear of the monitor, or because it has been handled the wrong way.
- You could be experiencing 'screen tearing'. This is caused by your videocard struggling for a moment.
- If you're running an older, analog monitor, it could be because the cable you're using is getting older and needs to be replaced.
AOC 17" Flat Monitor (silver)
Hello all.I had 2 AOC monitors with this kind of problem also and figured out the problem with this kind of monitor. All you have to do is to unscrew the monitor and get the control control switch buttons on its circuit board. There are four switch button that control the monitor with four pins each that attaches to the circuit board of AOC, another option is to replace the switch button with a brand new control switch button which can be bought to your local electronic shop. Now i had no problem with my AOC monitor because i literally removed those switch control buttons from its circuit board.
I have aoc monitor the problem is out of range
Describe your AOC S7M51, 17 in. CRT Monitor Problem. with external TV Tuner card connected, Message shows "Warning, Not Support, Out of range" and with CPU connected, the same message shows from the booting... ??? are AOC monitors trusted for the efficiency ?
Small texts display
Change the resolution , right click on desktop go to properties and then click on apearance tab. Change resolution on the slider bar under.
No power
If it won't power up the monitor is junk. There isn't much that one can do with a crt monitor which is considered to be obsolete.
I would recommend getting an lcd or led monitor instead of using a crt monitor.
