20 Most Recent
Samsung SyncMaster 551 15" CRT Monitor Questions & Answers
My Monitor is blinking in
Hello mrakmed,
Welcome, and thank you for using FixYa!
To answer your question: Your issue is one of three things, that will have to be checked and tested by a professional TV Repair Technician, if you consider this worth fixing.
1. Bad soldier joints around the Flyback Transformer.
2. Bad soldier joints around the 5v low/high power supply Transistors.
3. Some or all of the parts above, could be weak, and need replaced.
Have a great day!
9/15/2011 6:24:28 PM •
Samsung...
Answered
on Sep 15, 2011
Why does the color white
It is possible that there is a grid voltage problem due to a leak on the capacitor for biasing the grid . So check on the HT section for the capacitor in the grid to the CRT. replace all high voltage capacitors, REDUCE the SCREEN voltage on the LOT(( line output trnasformer)
This must solve the issue.
Thank you using Fixya.
8/9/2011 12:16:08 PM •
Samsung...
Answered
on Aug 09, 2011
Hi, I am using Samsung
if the stripes take 45 dgree and acolor of white then its aproblem in the line then you can decrease the brightness (the 3rd pot) and see
3/18/2011 7:57:23 PM •
Samsung...
Answered
on Mar 18, 2011
My Sumsang 17 inch monitor
Make sure the video cable is inserted properly at both ends. If it is, try another cable and see if that solves it. If it is hard wired to the monitor, make sure all the pins are in tact.
NOTE: replacement cost for monitor this old is very low so if you need to replace it, it shouldn't be too much.
3/3/2011 9:13:36 PM •
Samsung...
Answered
on Mar 03, 2011
My monitor displays in red
hi,
There is some dry soldering in the base board of you monitor. Its simple problem but the user cant rectify it. because removing the base board is not much easier. so consult some electronic repairing shop near you. It will not cost a lot. Also check the vga cable of your monitor, if possible remove the connection from the CPU and reconnect it and try one more time.. if you can do the same the i can assist you to do the same. feel free to contact me through fixya.
ok
2/19/2011 4:21:28 AM •
Samsung...
Answered
on Feb 19, 2011
After the installation of windows
Initially reset the monitor using the reset settings in the monitor and check it.If you were experiencing the problem only after installation of xp only means then it may be a problem related to the video drivers of the operating system or setting display settings to any wrong values .Check the video drivers are up-to-date and setting are default.
If the problem is not solved check the monitor using benchmarking tools and ensure hardware is correct some bench mark tools
http://www.benchmarkhq.ru/english.html?/be_monitor.html
9/20/2010 12:14:10 PM •
Samsung...
Answered
on Sep 20, 2010
About text sharpness
The monitor shouldn't be changing the settings itself unless you changed it. Try changing the brightness and contrast. Otherwise, it might be a video card issue.
11/30/2009 2:00:57 AM •
Samsung...
Answered
on Nov 30, 2009
Now in this morning when I on my computer the
its due to the discharging of high voltage 2 de ground through the pic tube surface, first u must discharge de eht knobe , clean suface well,
apply sparking preventer ( gel available in all electronic shops) reconnect knob it will be ok
10/24/2009 1:45:10 AM •
Samsung...
Answered
on Oct 24, 2009
Image shakes
check frequency settings and make sure its set at 60 htz,that is if your not in Europe
9/30/2009 8:39:31 AM •
Samsung...
Answered
on Sep 30, 2009
15" CRT Monitor samsung totally dead
Dear munu007 good morning this is viswanath
Don't worry I can salove UR problem
1.First U can check any physical damage in power supply (220/400v)Main capacitor,
2.And also check LOT It's OK Than Remove H O/p Transister, check SMPS output voltages ,voltages are currect That means SMPS is OK.Check Boosting FET IRF630(Q402)Change it New One,and also change the IC604 7805 Regulator.
Finally change LOT.
check any dry points (SMPS&Hori.)
5/19/2009 3:52:13 AM •
Samsung...
Answered
on May 19, 2009
Color Problem:
in Monitor CRT Red-Blue-green cathode guns are there.. Mixing of these colour we can get the original colour chrominace technique. if any of the colour gun is faulty we would get more REad or blue or green picture. Measure RGB voltages. you can verfify which gun is faulty. if then check RGB processing circuits. Else there might be problem Chrominance colour decoder system. Contact service centre
5/2/2009 4:08:37 AM •
Samsung...
Answered
on May 02, 2009
Urgeunte samsung syncMaster 551v
Hi and welcome to FixYa,
Initially, pls try
here for the wiring and schematics. The VGA pinouts may be referenced from
here.
Good luck and Thank you for using FixYa. Happy Holidays.
12/10/2008 4:43:58 AM •
Samsung...
Answered
on Dec 10, 2008
