20 Most Recent
Jensen VM9215BT 1-DIN 7" Widescreen LCD Multimedia Car Receiver Questions & Answers
Where do i ground my vm9215bt
Any bolt that connects to the metal would be good. I simple test light can be used to check for a good ground. If none are close, simply make your own with a self tapper screw and ring terminal. Most of the grounds are located around the steering column area.
Jensen vm9215bt car radio will not power up
Are the fuses okay? With the ignition switch off, you could hook up a temporary wire from the chassis of the car (the outside metal part of a cigarette lighter is a good ground) to the backside of the radio. Once secured, you can try the stereo again.
Jensen vm0312 is on, but tray will not flip up
It sounds like there may be an issue with the mechanical components of the DVD player, specifically with the tray. Here are some troubleshooting steps you can try:
- Check to see if the emergency eject feature is working. There should be a small hole on the front of the DVD player, and you can use a paperclip or a similarly sized object to push the button inside. This should manually eject the tray.
- Make sure that the DVD player is receiving power. Double-check all of the connections and fuses.
- Reset the DVD player by disconnecting the power for a few minutes, then reconnecting it and trying again.
- If none of the above steps work, it may be necessary to take the DVD player apart and check the mechanical components for damage or wear. However, this is not recommended unless you have experience with electronics repair.
If none of these steps resolve the issue, you may need to seek the assistance of a professional electronics repair technician.
How to bypass jensen
I just purchased the VX7020 and went to Settings-Language-typed in 5,4,3,2,1,0 but the menu never came up. Any ideas?
