20 Most Recent Planar 17' LCD MONITOR, TOUCHSCREEN, 1280 X 1024, XGA, 500:1 => Model PT1700M Questions & Answers
I've got a Planar PL2010M monitor that is brain-dead-
1. Try a different DVI cable. 2. Check the monitor's settings and make sure it is set to the correct resolution. 3. Try a different computer or laptop to see if the issue is with the computer or the monitor. 4. Try a different DVI port on the computer. 5. Try a different monitor. 6. Check the video card settings and make sure it is set to the correct resolution. 7. Try a different video card
2/21/2023 10:51:00 PM • Planar Computers... • Answered on Feb 21, 2023
Does the Planar PL1910M (Black) 19 in. Flat Panel LCD Monitor" Have a microphone"
No, there is no microphone listed in the specs, just integrated speakers
8/3/2015 6:36:19 PM • Planar Computers... • Answered on Aug 03, 2015
Can I use just the upstream hookup to connect an external monitor to my laptop? Also need to replace power cord. was not included Not the output needed Pwr rating says 12v dc 5.5a. That's all.
I use either VGA or HDMI connectors to connect to an external monitor. I'm not sure what you're asking on the "power cord". Are you asking about the charging "brick" and such? Or?
6/2/2015 11:50:06 PM • Planar Computers... • Answered on Jun 02, 2015
"Input not supported" even though it appears to be displaying correctly.
You will need to go to advanced settings under resolution options and set the display to 60hz refresh rate then go back to resolution and set your native, the problem is its probably trying to default to 75hz and is causing an issue
4/22/2015 2:40:31 AM • Planar Computers... • Answered on Apr 22, 2015
Planar monitor works but doesnt.
Try Another Monitor---If OK--Problem Is With Your Monitor---If Does The Same Thing--Problem With Computer Video.
3/18/2015 2:30:23 AM • Planar Computers... • Answered on Mar 18, 2015
0answers
Cannot select input OSD function on Planar PL1910M
Need reset on monitor BIOS. Call the support from distributors.
10/30/2013 5:39:45 PM • Planar Computers... • Answered on Oct 30, 2013
Computers & Internet Logo
0 questions posted
Top Planar Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Planar Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Planar Computers & Internet
Most Popular Question
planar pl1910m black 19 in flat panel
  • Computers & Internet
