20 Most Recent
Planar WS231 23.1 in. Flat Panel LCD Monitor Questions & Answers
Monitor not turning on
If the adapter goes out its most likely the adapter. Check the voltage on the adapter and try and match one up on the internet as the one you order from the company will most likely cost 10x more. You need to know the output voltage and amps.
Smearing of colors
I have a red tint on the left side of my display at all times. also red smear after any white boxes in display. Has anyone else had this problem?
I've got a Planar PL2010M monitor that is brain-dead-
1. Try a different DVI cable. 2. Check the monitor's settings and make sure it is set to the correct resolution. 3. Try a different computer or laptop to see if the issue is with the computer or the monitor. 4. Try a different DVI port on the computer. 5. Try a different monitor. 6. Check the video card settings and make sure it is set to the correct resolution. 7. Try a different video card
