20 Most Recent Samsung SyncMaster 793MB 17" CRT Monitor Questions & Answers
Samsung syncmaster 794mg monitor setting
i want vga cable D connecter connection
mainly vga cable broken that why i purchage one emitty d connecter scoket so i soldering this connection plz
12/2/2019 10:19:27 AM • Samsung... • Answered on Dec 02, 2019
0answers
Red colour display
Be the first to answer 1/29/2014 10:59:54 AM • Samsung... • Posted on Jan 29, 2014Be the first to answer
In Monitor Light Blue Colour is coming.
how to solve this?
8/29/2012 5:23:24 PM • Samsung... • Answered on Aug 29, 2012
Sir I have a DELL desktop CRT monitor which model no is E772p.It is not working .I opened the monitor and checked. I found that switching mosfet was short in power supply.It was taken out from the boa
You will need a service manual to get the correct part number, I tried to cross with my NTE data base no luck, went into ebay site punched in the original numbers came up empty.
5/3/2012 12:30:25 AM • Samsung... • Answered on May 03, 2012
The monitor which was supplied with a Compaq
Firstly try plugging the power cod from your PC into the monitor and power it on. Are there any LED lights on your monitor? If there is, then all you need to do is replace the power cord with a new one.
If there aren't any, it means that your CRT's internal power supply unit is dead and needs to be replaced. However, replacing these parts can be quite costly and involves labor charges since your monitor is out of warranty. I highly recommend that you look into the option of purchasing a new LCD monitor as these are pretty cheap nowadays.
Anyway, here is the service centre in Bangalore dealing with Samsung monitors:
#8 WOC Road, Mahalaxmipuram Post Near Swathi Hotel, Bangalore - 560085 KARNAKATA
Phone : 23496985
3/11/2011 4:04:23 AM • Samsung... • Answered on Mar 11, 2011
My samtron monitor working fine...just
you may have locked the OSD (on screen display for adjustments)
Press and hold the MENU button for at least 10 seconds to unlock it.
2/24/2011 7:21:03 AM • Samsung... • Answered on Feb 24, 2011
Default colour setting
Hi there please press the side button ( Menu) from there you can make the screen color default. Thanks you.
12/3/2010 11:02:55 AM • Samsung... • Answered on Dec 03, 2010
2answers
SyncMaster795 , scree turn yellowish.?
You are missing Blue color, it is either you have bent pins on the VGA cable or your monitor lost the Blue Gun Driving circuits (located on the PCB on the picture tube).
http://s807.photobucket.com/home/budm/allalbums
6/4/2010 3:08:44 PM • Samsung... • Answered on Jun 04, 2010
I cannot adjust the brightness or the contrast.
Cannot adjust brightness cause by inverter Board problem. You can send it to computer shop or TV shop to replace it. Because the CRT and CRT TV use the same tech.
5/11/2010 3:14:10 PM • Samsung... • Answered on May 11, 2010
How do i put a memory card from my camera into the
If your computer doesn;t have Built-in Card Slot(s), then you must get a USB - Memory card adapter. I have included an Ebay link so you can see what I mean.
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=usb+-+memory+card&_sacat=See-All-Categories
Then, you simply install the USB device and drivers. After which, you plug in the memory card to the USB adapter, the card will then show up as a "Drive" as such it can be used as normal, ie: Cut-Copy-Paste. The pics can then be used either straight from the Card, or copied somewhere else on ya PC, say desktop, and use them from there.
1/19/2010 11:05:17 PM • Samsung... • Answered on Jan 19, 2010
I am getting blank screen, after some time..Please
If you get a display when you first turn on then after, say, 10 minutes it goes blank, your power settings could be too low. Does it come back if you wiggle the mouse?
If you go into Start/Control Panel/Power Settings you should see a "Power off monitor" or similar. Either turn this to a longer time period or set to Never. The last option isn't going to do your electricity bill any favours though.
12/16/2009 8:29:17 PM • Samsung... • Answered on Dec 16, 2009
Resolution issue. Need hack.
use the F8 menu, select ENABLE VGA MODE that will force a 640 x 480 resolution for that boot.
12/4/2009 2:08:32 AM • Samsung... • Answered on Dec 04, 2009
I want to connect an external monitor to my Acer
If you have on laptop the vga exit, no problem, the VGA cable just works fine.
10/13/2009 12:01:47 AM • Samsung... • Answered on Oct 13, 2009
Problem in samsung syncmaster 793MB is that when
hi,
I think there is problem with your display card.
If you could try testing with another monitor you ll get confirmed. In that case you have to purchase another VGA card and install it then it works fine.
Regards
10/3/2009 12:36:31 PM • Samsung... • Answered on Oct 03, 2009
2answers
NO Display
time to replace the monitor, u fried the board, been there done that
7/25/2009 6:00:17 PM • Samsung... • Answered on Jul 25, 2009
2answers
Monitor colour problem
the VGA cable connecting from moniter to the computer is faulty so replace new
5/29/2009 5:25:09 AM • Samsung... • Answered on May 29, 2009
Samsung SyncMaster 793MB 17" CRT Monitor Logo
37 questions posted
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
SyncMaster Samsung
  • SyncMaster Samsung
Most Popular Question
default colour setting
  • Computers & Internet
