BenQ FP737S-D  17" LCD Monitor
Take a brief Survey Take a brief Survey   Add to My Products Add
Problems with BenQ FP737S-D 17" LCD Monitor?
Troubleshooting and Support
Solved Problems for BenQ FP737S-D  17" LCD Monitor RSS Feed Post a New Problem
benQ fp737 monitor
monitor is black, we turn the computer on and power button turns green but screen pls black the tower has been checked...
1 Solution
Benq monitor
only displays the benq for a split second. you said something about a capacitor. the only trouble im getting is getting...
1 Solution
BenQ FP737-D 17 Monitor
Monitor goes black after abt. 1-2 hrs. Green light is still on. Good ventilation on both monitor and PC.
1 Solution
i can't press any bottom on my LCD BENQ...
when i press it. it's not happen anything and i try very hard to press power bottom because its always not on . its...
1 Solution
white screen
Hi u left a solution conserning my benq lcd with a white screen conserning capacitors as i hav checked all caps on power...
1 Solution
BenQ FP737-D 17" LCD monitor
The monitor goes black after a while when on the net. Have to re-boot and it comes on again for a while.
1 Solution
white screen
hi bought a benq fp737s 17 inch monitor when it is turned on u get green light but a white screen ,screen stays white...
2 Solutions
Unsolved Support Problems
Unsolved Problems for BenQ FP737S-D  17" LCD Monitor RSS Feed Post a New Problem
advice
thanks for help, i dont think id trust myself to try fixing it myself. would it be easy? wouldnt i need static strips...
Post a Solution
found them
ah found them....so if i change these 4 will it make the screen work again?? do i test them as a normal transistor test...
Post a Solution
Vertical lines intermittantly on turn...
Remove mains and reconnect, usually ok for a while..
Post a Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Key Features
Size17"
Color Depth24-bit (16.7M colors)
Max. Resolution1280 x 1024
Dot Pitch0.264 mm
Monitor TypeFlat Panel LCD TFT (Active Matrix)
Technical Features
Form FactorDesktop
Digital Video Input StandardDigital Visual Interface (DVI)
Dimensions
Depth6.1 in.
Height14.8 in.
Width14.5 in.
Weight9.7 lb.
BenQ Contact Information
Main support number(866) 600-2367
Support FAX(949) 255-9500
Sponsored Links
Loading problems.
Top Monitor Experts
viziks
16 solutions
DVD Players, Monitors, Fax Machines
Ask Me
Wiz
Fix-4U
14 solutions
Monitors
Ask Me
Guru
bunnydaw
2 solutions
Kids and Family, Cars
Ask Me
Wiz
Repair Service
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
