20 Most Recent
Samsung Syncmaster 730B 17" Flat Panel LCD Monitor Questions & Answers
Screen says check signal cable - have check my cables....
Not really...
First check if the cable connected from the monitor is secured and properly connected to the video card of the CPU.
"Check signal cable" will only be display if there is no signal coming from the CPU.. that signal Passes through the video card..
Check the status of your video card.....and see also if the CPU is working and not dead set.
Hope this help...
Much appreciated if you rate this help.. thanks
1/20/2024 12:47:53 AM •
Samsung...
Answered
on Jan 20, 2024
How to turn off magicolor demo
Hello! can you solve your problem? i pushed up and down keys of the monitor at same time and the Magicolor Menu appear
1/20/2018 7:56:58 AM •
Samsung...
Answered
on Jan 20, 2018
How to change the resolution
- Native Resolution - 1280 x 1024 at 75 Hz
To change your screen resolution
- Open Screen Resolution by clicking the Start button , clicking Control Panel, and then, under Appearance and Personalization, clicking Adjust screen resolution.
- Click the drop-down list next to Resolution, move the slider to the resolution you want, and then click Apply.
- Click Keep to use the new resolution, or click Revert to go back to the previous resolution.
- if not display come pls select esc button to revert resolution.(don't press Enter)
9/4/2016 7:25:13 AM •
Samsung...
Answered
on Sep 04, 2016
Samsung SyncMaster 730B LCD monitor isn't backlit at all
Most failure in LCD monitors are due to cheaply made caps being use. If you are going to DIY repair, please read below, or if you are going to have it fixed then at least you will know if you are being ripoff or not.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
10/10/2013 12:22:10 AM •
Samsung...
Answered
on Oct 10, 2013
SAMSUNG LCD NO DISPLAY
reset the picture settings back to default. No more flickering and no more black outs! Give it a try... perhaps it works for you thx
1/20/2012 6:39:08 AM •
Samsung...
Answered
on Jan 20, 2012
I dont have a clue
I don't think your LCD has internal speakers. Does it have a small 3.5mm jack with a speaker symbol (like a headphone jack)? I was looking at a review of your model and there was no speakers listed on the specs.
9/19/2011 4:09:37 PM •
Samsung...
Answered
on Sep 19, 2011
Display only stays on for about a second.
Look for bad caps with domed tops, see my pictures here:
http://s807.photobucket.com/albums/yy352/budm/SAMSUNG/Samsung%20730B/
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
6/25/2011 3:04:52 AM •
Samsung...
Answered
on Jun 25, 2011
My monitor was not
I encounterred that same problem before. I just changed the video card cause it was corrupted.
6/18/2011 1:58:50 AM •
Samsung...
Answered
on Jun 18, 2011
My samsung 730b monitor has gone dark. is there a
this is probably a fault with the internal power supply or the backlight inside of the monitor. in certain Samsung monitors the capacitors go bad in the power supply, these can be replaced by re-soldering identical ones to the power board, which is fairly easy to do if you know how to solder. if that isn't the problem, the back lights have gone bad, which is very dificuly and probably expensive to replace. However, the monitor could be fine and you could have just altered the brightness/contrast or some other settings in the menu on the monitor itself, you could try selecting the factory reset option if it has one. Another thing that could go wrong is if someone has messed with the display calibration settings on the computer itself (unlikely).
5/2/2011 3:24:54 AM •
Samsung...
Answered
on May 02, 2011
A friend of mine gave
Most likely a VGA cable or DVI cable. I would place my bets on a VGA cable (both ends are blue).
4/7/2011 10:16:15 PM •
Samsung...
Answered
on Apr 07, 2011
