20 Most Recent
Canon ZR10 Mini DV Digital Camcorder Questions & Answers
Camera is eating the tapes during playback.
Tape mechanism problems can be quite complicated but they can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If t
his response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Camera will not accept tape
Tape mechanism problems can be quite complicated but they can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be diagnosed by a qualified service technician.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Tape deck won't eject tape
The tape might be wrapped around the head or the capstan. The mechanism is delicate so you risk more damage by trying yourself - check with some of the repair shops on the Fixya home page for prices to remove the tape.
Canon ZR 10 Digital Video
Usually the cassette mechanism just needs cleaning when this happens, and a camera repair or tv repair shop can clean it. You can try a dry or wet cleaner, and they're available on the net (just google it), or try
Best Buy or Radio Shack.
If a cleaning doesn't fix the problem, it will have to be serviced.
Good luck, and hope this helps.
Canon zr10 mini dv camcorder
Tape mechanism problems are quite complicated but they can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be diagnosed by a qualified service technician.
My Canon ZR10 video camera will not load a casset
This is usually caused by a defective component in the tape detection circuitry and can be repaired fairly inexpensively. However, it’s not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
Cassette jam
I had this problem, and here is how it was resolved.
My cassette would not pop out when I opened the door with the camera
turned on. When I turned off the camera and opened the door, it slid
out much further, but still failed to pop open so that I could remove
the tape. Then it slid back in.
Remove the battery, and have the camera off, but make sure the power cord is connected. Open the door until the tape slides out further than at other times. (Note:
It intermittently slides out further when the camera is off. Sometimes
it will not slide out any further than when it is on.) When the tape is
slid out as far as it will go, quickly remove the power cord. The tape
will stay in the slid-out position. Now, at the bottom side of the tape
door there is a curved channel for a small pin to slide in. This
channel has a 90% curve at the bottom of the channel to catch the pin,
which holds the door closed. Push that pin back a little (toward the
lense) to get it to go around that 90% curve, and the door will pop
open so you can remove your tape. The ribbon of your tape will be
jammed in the camera a little, so you will have to be careful and move
the ribbon around a little until you can get it out freely.
This worked for me twice. I did not try putting a tape in again.
I hope this helps.
Can I download a video
You need to have DV port (IEEE1394 port) in your computer and hook camcorder with computer using 4pin to 4pin DV cable.
Install supplied software cd in your computer so your computer can recognize your camcorder and read movie files coming from camcorder, press play button on camcorder and save files in computer.
There is an alternate way, hook camcorder with stand alone dvd recorder either by DV cable or RCA AV cable, playback tape in camcorder and burn dvd in dvd recorder, finalize it and put that dvd in computer, copy/ paste files some where in computer.
Hope this info will help you.
Thanks.
