20 Most Recent
Canon MV650i Mini DV Digital Camcorder Questions & Answers
Is there a reset button on the mv650i?
Camera's do have microprocessors, but don't need any reset. If they act strange, removing the battery and after a few moments replacing is, will do the same trick as a cold boot from a computer. If the same error keeps coming back, something more serious is wrong. Most of the time there is a hardware failure. And no other reset could solve that.
If you did not use the camera for a long period, check if all contacts are clean and shiny. contacts to be cleaned (if needed) whit a dry cloth or cotton swab. Never use sharp tools in or close to a camera.
Cassette removal from dead Canon MV650 Camcorder
I just solved my own problem by disassembling the camcorder until I had access to the little motor which operates the eject mechanism. It sits on the corner of the mechanics subassembly, close to the cassette. By applying about 3.5 Volts DC from a regulated power supply to the two motor contacts, it started to operate (test which direction it needs to go by trying both polarities) and lifted the cassette out of the play position and ejected it. Only since the tape was still wound around the drum, I had to use a thin tool to turn the cassette hub in order to tighten the tape a bit. Then the protective cover of the cassette closed and I could slide the cassette out of the slot by hand. Bingo!
MC does not detect MV650i through USB cable. How
Seems like you are using out of date driver, install the most recent driver onto your operating system. Visit this link to download driver for
MV650i & Select operating system from the list and start downloading.
- Make sure that you have install canon digital video software onto your system (Computer) , If not then install it through the included disc & follow the on screen instruction, restart your computer when you completed the installation.
- Disconnect computer and camcorder both & then restart both device to clear any communication issue. Make sure memory card is inserted into you camcorder before connecting.
hope this will solve the issue,
Good luck and have a nice day..!!
Battery pack use
I have a similar problem. My MV650i works from the mains power but not from the battery even though I have tried new battery packs.
Can't record or take photos
Yet another CCD sensor problem ( in your case it is outputting nothing so you get blank screen as opposed to heavily distorted picture which is also very common). Properly manufactured sensor lasts 10 years + so you should have this repaired free of charge if you can.
Replace CCD block.
No picture through viewer or on screen
This model was sold under the name ZR70MC in the US. There is a Canon Service Notice which covers this model worldwide. The US version is
here. Canon will repair your unit at no cost regardless of warranty status. Contact your regional Canon service agency.
Importing camcorder videos from tape to pc
what cable are you using to connect your camcorder to the pc? and did you try to look at the manual for that situation. see also the settings from your camcorder before you connect it and look for the memory storage use or tape usage so that the appearance on the computer will be tape and not the memory card. can you pls give me some specific problems and details so that its not hard for us to solve your problem.
Needs
1.Cables like usb or firewire
2. installer cd camed from your camcorder
3. uploading software such as ulead movie director or movie maker, Windows moviemaker, Nero movie maker etc.. or whatever software you have.
4. Edit and save
the following steps are needed to transfer your videos to your computer.
tell me what you have.
CHARCOIS
Downloading videos
Use USB cable to connect your device to your computer and you should have a software installed in your computer to be able to capture videos from the tape inside on your camcorder. This software will edit and save what you have been recorded and captured. If any question just ask me. thank you for using fixya, hope that helps you!
CHARCOIS
