20 Most Recent Canon MV700i Mini DV Digital Camcorder Questions & Answers
2answers
How to transfer videos to my pc
I assume you mean videos you've recorded on the MV700i? You need a FireWire card for your PC.
http://www.firewire-1394.com/
But most computer shops will sell them. The camcorder - from memory - comes with a FireWire cable. The "small end" plugs into your camcorder - and the "big end" into your new FireWire PC port.
Then you just need Windows Movie Maker to do the job. You can download to the PC in AVI format if you wish - but for most purposes use "Other settings" -> "Video for local playback (2.1 Mbps)"
12/13/2019 6:55:24 AM • Canon MV700i... • Answered on Dec 13, 2019
0answers
How do i get the casette out of the canon mv700i ? i see a push button on the casette but it doesnt work.
You may need to have a charged battery pack attached to the camcorder (or use the mains power lead, if applicable), so that the camcorder has power to open the cassette door. You may even need to turn the camcorder on. These are safety refinements so that the eject button does not accidentally open the door, leading to possible loss of cassette or damage to the camcorder itself.
1/27/2016 10:52:29 PM • Canon MV700i... • Answered on Jan 27, 2016
0answers
No picture and white horizontal bars on screen
This is most likely caused by a damaged or misaligned video drum and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
2/7/2011 3:51:46 PM • Canon MV700i... • Answered on Feb 07, 2011
I need to copy videos
You need a cable that is called by many names- Firewire, DV, IEEE 1394, and Sony call it i.Link. Many names for the same thing, but they are mostly just one type, with a small plug for the camera end and a larger one to fit the PC. The easiest way to get the right cable is to search Amazon for "canon mv700i firewire". I found a couple right away for less than $10.
1/27/2011 10:52:03 PM • Canon MV700i... • Answered on Jan 27, 2011
I have a Canon mv700i
This is usually caused by an oxidized or defective Audio/Video drum. Try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be serviced by a qualified service technician.
1/18/2011 7:07:44 PM • Canon MV700i... • Answered on Jan 18, 2011
0answers
Image wont come up on screen and its flashing me
No. The power converter inside the camera is damaged some how. It says the battery needs charging because power cannot get to the main circuit - it needs to be taken apart and isolate the crack or open contacts.
11/24/2010 9:51:06 PM • Canon MV700i... • Answered on Nov 24, 2010
I have a Canon MV
Most PCs have USB ports, but no Firewire port. Macs often have a Firewire port but may not have USB. You could fit an add-on Firewire interface card to a desktop PC, but not to a laptop.
11/23/2010 11:09:25 AM • Canon MV700i... • Answered on Nov 23, 2010
My canon mv700i will not power up i try to charge
The first step is to ensure you have a good battery, and a full charge on it. If the battery is bad, or has a shorted cell, the unit will not power up. Second thing to check is that the battery's contacts, and also the contacts inside the camcorder, are clean, and not oxidized. You can clean them with a qtip and alcohol. The next thing to suspect is the on/off switch. It could be faulty. The only way to check it is to disassemble the camera, and use an ohmmeter across its terminals. This can be quite a task, and you might want to have it serviced, at this point. If you do choose to have it serviced, get an estimate first. Often, the cost of repair comes close to or exceeds replacement cost of a new one. Of course, other problems can cause this, and they're more serious, and costly to repair.
Here is a good blog to read for this problem, it covers various scenarios.
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
Good luck, and hope this helps.
6/19/2010 7:44:54 AM • Canon MV700i... • Answered on Jun 19, 2010
Replay heads not playing back
Have you used the same tapes over and over again? If so then reclean your heads and see if things work with a brand new tape. If this IS the case then I don't think what's on the original tapes will be salvagable.
6/14/2010 9:09:14 AM • Canon MV700i... • Answered on Jun 14, 2010
I have a mv700i - how do I download video to my PC
SEE the other solutions on this site. You need a fireWire card for your PC.
6/14/2010 6:34:27 AM • Canon MV700i... • Answered on Jun 14, 2010
2answers
No picture
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} It has been found, that in rare case, some of the CCDs, used in Canon digital camera and digital video cameras, have a problem that causes abnormal image output. Free repairs will be made for affected products in cases where it has been confirmed that the internal CCD wiring has come off.
Contact you local Canon Repair Centre
6/14/2010 6:31:44 AM • Canon MV700i... • Answered on Jun 14, 2010
I have a flashing red symbol on my screen, that
This is the warning that the backup battery needs replaced.
Here is a link to your manual:
http://files.canon-europe.com/files/soft29694/manual/MV600i_IB_ENG.pdf
Go to Page 17 for a description and instructions for replacement. Remember to power it with a power source when replacing or you will lose all your settings.
Thanks for using Fixya. Please take a moment to rate this soution.
3/30/2010 4:07:24 AM • Canon MV700i... • Answered on Mar 30, 2010
Camcorder will playback ,but shows no image when recording
Can you make it go while attached to a Power Adapter ? and with battery OUT, try that first. IF it works, buy a new battery for that model. Batteries can go so flat they cannot be charged, without special equipment,and even then they may not resurrect. funnily enough, leaving things without current running through them, or powering up,every few weeks, etc, can often cause a problem, strange huh?
3/23/2010 11:39:00 PM • Canon MV700i... • Answered on Mar 23, 2010
Canon MV700i Mini DV Digital Camcorder Logo
52 questions posted
Top Canon Video Cameras Experts
NOEL
NOEL
john h
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
View Most Popular
Canon Video Cameras
  • Canon Video Cameras
Most Popular Question
canon mv700i
  • Video Cameras
