20 Most Recent
Relisys TL565 15" LCD Monitor Questions & Answers
Cannot remove Auto adjustment message
This isn't a solution, but a warning to anybody passing my 2nd floor flat. If no-one can come up with an answer, the ******g monitors going out the window !!
Screens works for 5 mins then goes blank!!!!!
It could also be that the video card is not compatible with this monitor. After the pc boots up, can you get into windows? Does the monitor always go out at a specific time on boot? Say for example; you boot the pc, windows startup splash screen comes on; screen does a quick flash and goes blank. Then it maybe the BIOS setting for the video. Try changing the IRQ setting. You could also try putting the video card in another slot. Do you have the manual for the motherboard?
Ray
How to use speakers
If your monitor has built in speakers then there should be a small jack in the back, usually green in color. You would need to run an audio cable from the monitor to the proper jack on the back of your computer, usually the green color like on the monitor. Once connected you should be able to use the volume button on the monitor to adjust to your preference. But remember external speakers are usually a higher quality than those built in to the monitor. Hope this helps.
Green tinge
How long have you had this monitor? Is it a flat panel or CRT? Who is the manufacturer? what type of PC are you using? What type of OS are you running? I can try to answer your question if you answer these?
