20 Most Recent Sceptre X 7 Komodo II 17 in. Flat Panel LCD Monitor Questions & Answers
0answers
0answers
All of a sudden I have blue line vertical right of
Vertical lines on an LCD screen are, as a general rule, not good! Your screen is heading for the drain!
7/21/2010 8:28:55 PM • Sceptre X 7... • Answered on Jul 21, 2010
Monitor goes black after a moment
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
4/18/2010 12:51:01 AM • Sceptre X 7... • Answered on Apr 18, 2010
What does the firmware update mean?Does it update to wifi
"Update" does not mean "upgrade." You can update the firmware in the microprocessor with a newer version, so that it runs better in most cases. You cannot upgrade to better hardware using this method.
5/29/2017 6:42:10 PM • Sceptre... • Answered on May 29, 2017
Scepter 22in led monitor not recognizing android tv box, no menu comes up
will the monitor work with your computer?
3/19/2017 5:29:10 AM • Sceptre... • Answered on Mar 19, 2017
Fix horizontal lines
Just buy a new computer monitor. It is not worth the cost to repair it.
10/2/2015 2:31:26 AM • Sceptre... • Answered on Oct 02, 2015
Sceptre screen flashes with lines. Any ideas
You need to determine if it is the monitor or the video card. First step is if you have another computer, connect the monitor to that and see if it works ok. If not, it is the monitor and likely the video board. Depending on the age of the monitor it might be better to purchase new monitor.
6/21/2015 5:54:09 PM • Sceptre... • Answered on Jun 21, 2015
0answers
Sceptre X 7 Komodo II 17 in. Flat Panel LCD Monitor Logo
9 questions posted
Top Sceptre Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Sceptre Computers & Internet
Most Popular Question
all sudden blue line vertical right
  • Computers & Internet
