20 Most Recent Canon GL2 Mini DV Digital Camcorder Questions & Answers
3answers
My canon gl2 lcd screen and viewfinder black
Same thing happened to me. No display, no menu, no S-video output while in camera mode, but in VCR mode all was OK. Turning power off and on did not help until I also disconnected the AC power adapter. BTW, Mr. Riggins did not read the question before he answered.
12/17/2021 8:17:50 PM • Canon GL2 Mini... • Answered on Dec 17, 2021
I just had My GL2 serviced the only problem
The selector switch may be out of time. A plastic gear may have come loose from the shaft it's mounted to. A thorough inspection is necessary to find the failed part.
11/29/2017 6:58:47 PM • Canon GL2 Mini... • Answered on Nov 29, 2017
Video from Canon GL2 to my sony vaio windows vista and I already updated to zoombrowser EX 6.1
Suggestion: Remove the memory chip from the Canon and get a reader that plugs directly into your USB port on the vaio. Available online or at any computer shop or big box store. You should be able to open the photos directly from the chip. They'll be in a DCIM folder - you may have to easter-egg around a bit, or search for *.jpg Lots faster and less frustrating than the camera's software interface.
8/3/2017 1:41:43 AM • Canon GL2 Mini... • Answered on Aug 03, 2017
Where is the lithiam battery on a canon gl2 camcorder
This information will be in the camcorder manual. If you have no manual, you can download a manual for almost any equipment by Googling the make and model followed by the word Manual, then follow the appropriate link(s).
3/3/2017 7:18:31 PM • Canon GL2 Mini... • Answered on Mar 03, 2017
3answers
Canon GL2 says eject tape while recording
Hope this video helps explain the problem you are having.
9/16/2016 7:29:30 PM • Canon GL2 Mini... • Answered on Sep 16, 2016
It won't come at all. I have tried battery and power pack but no power.
same man, did you fix it? THANKS IN ADVANCE
11/30/2015 10:21:42 PM • Canon GL2 Mini... • Answered on Nov 30, 2015
How do i get distortion lines out of the camera?
Do you mean distortion from shooting at wider angles? If you, you'll either need to do it when you import the video into your editing program or not use such a wide angle in your shots.
1/6/2015 4:07:09 PM • Canon GL2 Mini... • Answered on Jan 06, 2015
How would i take away distortion lines that show up in my camera?
1/6/2015 4:06:49 PM • Canon GL2 Mini... • Answered on Jan 06, 2015
How to connect canon gl-2 camcorder to computer
Are you using the proper Firewire cable to connect? Also, the GL2 has had issue with the Firewire port going bad. Try a different cable and see if that helps. It can't be a USB-Firewire cable either.
1/6/2015 3:57:32 PM • Canon GL2 Mini... • Answered on Jan 06, 2015
How do I fix the tracking on a video already shot
You cannot do any corrections. The video tracking signal is set. The best that you could do is use editing software to try and crop it.
9/12/2014 2:28:32 AM • Canon GL2 Mini... • Answered on Sep 12, 2014
2answers
Tape will not eject from camera.
hit it on your palm a couple of times
8/8/2014 2:57:09 PM • Canon GL2 Mini... • Answered on Aug 08, 2014
My Canon GL2 Tape Door Will not Close and Just
Issue: "Remove the Cassette" message in LCD
Solution: Remove cassette and reload and/or try a new tape
Remove cassette and reload and/or try a new tape ---
http://www.usa.canon.com/cusa/support/consumer/camcorders/professional_camcorders/gl2#ServiceAndSupport
8/8/2014 2:55:19 PM • Canon GL2 Mini... • Answered on Aug 08, 2014
2answers
When I put a mini
8/8/2014 2:54:30 PM • Canon GL2 Mini... • Answered on Aug 08, 2014
4answers
GL2 does ne rewind
I doubt it is something in the settings. Step 1: The tape may be causing the camera to "reject" it. In other words, it thinks there is something wrong with the tape so it is warning you with the error message. Perhaps the cassette has been damaged slightly. This error can also happen when the tape has been used often or taped over a few times. MiniDV tapes are not media that can be recorded over and over again. Solution: Try using a new tape. 2. The camera may need to be cleaned. The recording heads may be dirty and it doesn't matter what tape is placed in there. Solution: Purchase a cleaning tape from a consumer electronics store. Make sure you read the directions very carefully. These are cheap fixes. If it works, great. It would also be good to know what it CAN do. Does it play in the VCR mode? Does it record? And can you view it in the VCR mode? Has it changed in any other way, i.e. is it making a strange noise when it starts to rewind, when before it didn't? Let me know how it goes.
8/8/2014 2:53:27 PM • Canon GL2 Mini... • Answered on Aug 08, 2014
Canon GL2 Mini DV Digital Camcorder Logo
247 questions posted
Top Canon Video Cameras Experts
NOEL
NOEL
john h
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
View Most Popular
Canon Video Cameras
  • Canon Video Cameras
Most Popular Question
okay put in sd 16gh something card
  • Video Cameras
