20 Most Recent Canon Elura 90 Mini DV Digital Camcorder Questions & Answers
How to transfer mini dv tape to dvd or vcd
you should have a few choices with this model: usb, firewire, composite a/v..
this link will take you to canon's download page for your camera,
the dvmessenger app should let you view your camera on the comp, use it for videoconferencing, and view it online, as well as remotely control it, although it may not let you transfer much.
your camera should have come with an installation cd that included digital video software. if it did not, you will have to contact canon for a replacement cd.
i would recommend downloading the product manual from the above site and checking page 134
in addition you can use the memory card to transfer files via a memory card reader on the pc, these can be picked up inexpensively at most camera and computer stores. your camera however should be fine if you are using windows xp and the usb cable for your camera.
hope this helps,
trin
10/10/2014 1:45:56 AM • Canon Elura 90... • Answered on Oct 10, 2014
The camera is automatically zooming in, I do not
This is a failure in the zoom switch assembly and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
11/29/2010 7:57:24 PM • Canon Elura 90... • Answered on Nov 29, 2010
The sd card is not
Go in the camera options and format the card. If your camera does not have this option or it can't complete the format it means that :
Your card might not be formatted with the correct File System. Move your SD Card to a computer with card reader and Format with FAT32 File System the move it to camera. If the camera gives the same error, format the SD card with the NTFS file system the try again in your camera. If the SD card still don't work try FAT Fyle System.
11/10/2010 3:11:00 PM • Canon Elura 90... • Answered on Nov 10, 2010
We are trying to get some Hi8 footage onto our
the procedure is the same ..for vhs...but you will need a firewire cable ..also ..and a program that will import from device...The issue is that Im not sure what program you need for MAC ..but if you have a windows computer available to do that ..things are getting simple..just follow this video..
http://www.5min.com/Video/Windows-Movie-Maker---import-from-a-DV-tape-6876
So...if you have a movie maker in your Mac ..the procedure will be the same ,just playback in the camera ...be sure it is detected by the firewire cable...and record (import ) with the movie maker...
Please dont forget to rate if this helps...
5/9/2010 5:32:53 AM • Canon Elura 90... • Answered on May 09, 2010
Tape will not eject
Hi, The tape sounds to have undone inside your machine, be careful if its important home video etc. Try use a blunt kitchen knife to prise it open, the camera drawers are stronger than they look, this worked for me. Thanks
Mark
5/3/2010 3:37:06 PM • Canon Elura 90... • Answered on May 03, 2010
I have an Elura 90. The cassette door opens but
When ejecting the tape you must hold the eject switch down for a full second. There are two stages to the eject process just as there are with the insertion of a videocassette. Hold the button in position long enough to hear the motor mechanism start.
12/13/2009 9:11:52 PM • Canon Elura 90... • Answered on Dec 13, 2009
No sound on any tapes
Katie, we need a little more information. Are you saying that when you shoot footage and play it back on the camcorder you hear no sound? Have you tried plugging in the A/V cables and connecting the camera to a television?
12/13/2009 9:07:30 PM • Canon Elura 90... • Answered on Dec 13, 2009
Is there a better (brand)
One thing that can change the tape quality is making sure you are using th 60 minute recording mode vs the 90 minute EP recording mode. If you record alot, you should clean the tape heads every 6 months as well. I haven't really found any bad tapes out there (I'm sure there are some). Usually Sony and JVC are good choices to use.
12/23/2008 11:14:14 PM • Canon Elura 90... • Answered on Dec 23, 2008
2answers
Canon elura 90: won't load tapes
Make sure the power is on this unit and you are pluged into a good source of power. The disk tray needs power to lower. A lot of tapes get loose in there case and need to be fast forwarded and then rewound completely in order to help spool them properly in their case. And what you are experiencing sounds a lot like this. It is also possible that you need to buy a head cleaning unit for your elura and run it in the camera for 10 secs and then try again. (Did you try this with a New tape? or just used ones?) We bought a small tape rewinding unit for around 39 dollars that helps us to rewind the mini DV tapes without adding wear and tear on our camera and it seems to help with the issue of loose tapes in the camera getting rejected as they won't wrap around the tape head as nice.
12/14/2008 6:46:57 PM • Canon Elura 90... • Answered on Dec 14, 2008
How to remove a tape out of a canon es55 that will not power up even if the battery is charged
If you suspect that your JVC camcorder may have been damaged by plugging in the wrong power cord, it's possible that the cassette mechanism may not release as intended. However, you can try the following steps to manually release the cassette:
  1. Turn off the camcorder: Make sure the camcorder is turned off and unplugged from any power source.
  2. Locate the cassette release button: The cassette release button is usually located on the side or bottom of the camcorder near the cassette compartment. It may be labeled "eject" or have a symbol that looks like a triangle with an arrow pointing up.
  3. Press the cassette release button: Press and hold the cassette release button for several seconds to see if it releases the cassette. You may need to press it firmly or use a pointed object like a pen or pencil to press it.
  4. Manually release the cassette: If the cassette release button does not work, you can try manually releasing the cassette. Look for a small hole on the camcorder near the cassette compartment. This hole may be labeled "emergency release" or have a symbol that looks like a triangle with an arrow pointing down. Insert a straightened paperclip or similar object into the hole and press gently to release the cassette.
If you are unable to manually release the cassette, it's possible that the camcorder has been damaged beyond repair.
2/22/2023 9:34:00 AM • Canon Video... • Answered on Feb 22, 2023
My Canon ZR-40 Mini DV Camcorder only has a blank screen when in VCR mode. Cannot use any VCR functions. When I try to record, it says 'No Card' but there is no slot for an SD card at all.
It's possible that the video head is dirty or damaged, which is preventing the camcorder from playing back tapes. You may need to clean or replace the video head. As for the "No Card" message, it may be a default message that appears when the camcorder cannot detect a tape. Check that the tape is inserted correctly and try a different tape to see if the issue persists. If the problem continues, it may be a more serious issue with the camcorder that requires professional repair.
2/14/2023 8:31:25 AM • Canon Video... • Answered on Feb 14, 2023
My CANON MV940 DIGITAL VIDEO CAMCORDER cant charge.....when i plug it in the battery charge indicator does not flash or light up
If your Canon MV940 digital video camcorder is not charging when you plug it in, there are a few things you can check to try to determine the cause of the issue:
  1. Check the power adapter: Make sure that the power adapter is securely plugged into the camcorder and that the outlet you are using is working. Also, check that the adapter is not damaged or malfunctioning.
  2. Check the battery: Make sure that the battery is inserted correctly and that it is not damaged or worn out. If the battery is old or has been used for a long time, it may no longer hold a charge and will need to be replaced.
  3. Check the charging port: Make sure that the charging port on the camcorder is clean and free of debris. If there is debris blocking the port, use a soft-bristled brush or a can of compressed air to clean it out.
  4. Check the battery terminals: Make sure that the terminals on the battery are clean and free of debris or oxidation. Clean the terminals using a soft-bristled brush or a pencil eraser.
  5. Check the firmware: If the problem persists, check to see if your camcorder's firmware is up to date. If it isn't, update it.
If you've tried all of these steps and you still cannot charge your camcorder, it's possible that there is a hardware issue with the camera. In this case, you may need to contact Canon support for further assistance. https://amzn.to/3WisSDI
1/16/2023 6:03:24 AM • Canon Video... • Answered on Jan 16, 2023
Need help understanding a transfer from the Canon MV830i camcorder to Macbook
  1. To transfer video footage from your Canon MV830i camcorder to your Macbook, you will need a FireWire cable and a FireWire USB adapter. This cable connects the camcorder to your computer, and the adapter allows the FireWire connection to be recognized by your Macbook. You can find this cable and adapter on Amazon or other electronics retailers.
  2. To transfer the footage to your computer, you can use the built-in iMovie software on your Macbook. This software lets you capture the footage from your camcorder and import it into the program for editing.
  3. You can reuse the tapes by recording the footage you have already captured. Make sure you have transferred the footage to your computer before recording it.
  4. Some other advice:
  • Make sure your camcorder is in VCR or VTR mode before connecting it to your computer.
  • Test the connection and transfer process before filming important footage.
  • Check the manual of the camcorder for detailed instructions on how to transfer footage.
  • Be patient; transferring footage from a camcorder to a computer can take some time.
Remember that transferring footage from a camcorder to a computer can be a bit complicated, but with some patience and practice, you'll get the hang of it. Remember always to consult the manual of the camcorder for detailed instructions and always keep your computer and software updated.
1/14/2023 1:36:51 AM • Canon Video... • Answered on Jan 14, 2023
I want to connect a Canon ZR 800 using firewire to my MacBook Pro.
To connect your Canon ZR 800 camcorder to your MacBook Pro using a Firewire connection, you will need a Firewire cable and a Firewire port on your computer. Here are the steps you can follow to connect your camcorder to your MacBook Pro:
  1. Locate the Firewire port on your MacBook Pro. It is usually located on the side or back of the computer and is marked with a symbol that looks like a small lightning bolt.
  2. Connect one end of the Firewire cable to the Firewire port on your MacBook Pro.
  3. Locate the Firewire port on your Canon ZR 800 camcorder. It is usually located on the side or back of the camcorder and is marked with a symbol that looks like a small lightning bolt.
  4. Connect the other end of the Firewire cable to the Firewire port on your camcorder.
  5. Turn on your camcorder and set it to playback mode.
  6. Open the video editing software on your MacBook Pro and choose the option to import video from a Firewire device.
  7. Follow the prompts in the software to import the video from your camcorder.
I hope this helps! If you have any further questions, don't hesitate to ask.
1/7/2023 11:13:11 PM • Canon Video... • Answered on Jan 07, 2023
Canon vixia recording with color problems
If you are experiencing color problems while recording with your Canon Vixia camcorder, there are a few steps you can try to troubleshoot the issue:
  1. Make sure that the camcorder is properly focused. If the focus is off, the colors may appear distorted or blurry.
  2. Check the lighting conditions. If the lighting is too dim or too bright, the colors may appear distorted or washed out.
  3. Check the white balance settings on your camcorder. If the white balance is not set correctly, the colors in the video may appear inaccurate.
  4. Clean the camcorder's lens to remove any dirt or smudges that may be affecting the image quality.
  5. If you are using an external device, such as a monitor or TV, to view the video, make sure that it is properly calibrated.
If you have tried these steps and are still experiencing color problems with your camcorder, you may want to try contacting Canon customer service for further assistance. They will be able to provide you with more specific troubleshooting steps based on your particular camcorder and the issues you are experiencing.
1/7/2023 11:08:19 PM • Canon Video... • Answered on Jan 07, 2023
Canon es55 video camera. Everytime I put a tape in, it ejects it. If I take the tape out, and close the door,it will will automatically close and stay closed
Hi, Please first make sure that there is nothing within the video camera that was accidentally lodged into the space where the tape would fit. Also, please double check that you're orienting the video tape properly when inserting it into the video camera. I would also test different tapes to see if the issue is consistent. Also, you might have to rewind each tape because I think if the tape is at it's end, then it automatically leads to the tape being spit out. Thank you.
10/11/2022 12:29:06 AM • Canon Video... • Answered on Oct 11, 2022
Am I wise to try and fix my [NTSC] Canon ES2500A video camcorder myself or should I just try to replace it with a refurb to transfer my Hi8 video to digital?
Hi, you might be able to get the camera fixed by geeksquad/Bestbuy so I would advise you to try this first before purchasing a replacement. Thank you.
10/1/2022 10:19:09 PM • Canon Video... • Answered on Oct 01, 2022
Canon Elura 90 Mini DV Digital Camcorder Logo
21 questions posted
Top Canon Video Cameras Experts
NOEL
NOEL
john h
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
View Most Popular
Elura Canon
  • Elura Canon
Most Popular Question
camera automatically zooming in not
  • Video Cameras
