20 Most Recent
Sony VAIO FXA63 Notebook Questions & Answers
I NEED THE DRIVERS SOUND AND VIDEO
Here is the requested audio drivers and
here is the video ones. Both are for Windows XP op. system.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Sony bios password
You could try removing the cmos battery for a few minutes and letting it reset your bios. Not sure if you feel comfortable enough messing arounnd on the motherboard though.
Can not watch videos on Sony Vaio PCG-38L model laptop
Uninstall both the flash player and the browser, then reinstall, first the browser, then the flash player. If you are using Internet Explorer, I'd suggest you to use another browser. A good one is the Mozilla Firefox (http://getfirefox.com). If the problem persists, it might be another process using too much CPU power, hit "Ctrl+Shif+Esc" and click on the tab "processes" and sort which program is using more memory/cpu, after locating it, hit the button "end process", or "Delete" on your keyboard, then click "Yes" (if it's an unimportant process, only do it if you are absolutely sure if the process is not important for your work/task at hand). If the problem persists, I'd suggest you to backup and format, but only as a last resort. Then restore the backup and install the player again and see what happens.
Please i cannot have access
just remove the battery from the mother board of the pc by removing the back cover and replacing it again after 2 minitues ....
My computer will not turn
Hello.
If you used a wet solution to clean the keys, you may have affected the notebook.
But, first, disconnect the cables and remove and reinsert the battery. Then, connect the power adapter and try again.
If still a problem, disconnect all the cables and remove the battery. Connect the power adapter. If it works, the battery is faulty. If it does not work, it's possible that part of the inside of your notebook got wet.
Hope this resolves your problem.
Good day. I have a
For a laptop, "it is what it is" -- namely that the laptop was designed to use 8MB of your RAM for "video" purposes.
Unlike a "desktop" computer, the video-card is not a "user-replaceable" part.
If your computer is "slow" when downloading from YouTube,
start downloading a video, and click 'pause', to allow the download
to continue, while the playback has been paused. Then, a minute later, click 'resume', to see if the downloaded video "plays" at the "normal" rate, without any video artifacts.
Will not play DVD
To change the resolution you have to look for the specific resolution that is required. Make sure you select monitor one and plug and play in properties when you right click on the desktop . Then click on advanced. Choose the monitor tab and uncheck the hide all modes. Make sure it is 60 Hertz. Then click on adapter. Then click on list all modes and select the preferred one. After you click on apply you will get a box saying are you sure and you have to click on yes in the next five seconds . And you will have the resolution changed !
Restored system using Restore Disc. Cannot update
1.format your system
2.reinstall windows xp service pack
3.install advance system care software
4. Advance system care (registry cleaner)
http://download.cnet.com/Advanced-SystemCare-Free/3000-2086_4-10407614.html
5.install antiavir9 antivirus software
6. your problems will be solved, try it.
