20 Most Recent Yakima RocketBox Questions & Answers
When I worked boats years ago. We had a brand new boat gettin water in it. Finally found that the bell housing had a porrous casting in it allowing water to seap in from the exhaust port.
Boating | Answered Yesterday
ALWAYS BY THE MACHINE OPERATOR AND NORMALLY IN THE SHIFT CONTROL BOX OR DASH BOARD
Boating | Answered on Apr 12, 2019
specifically or in general? Now single system depth finders are pretty rare as you know have GPS and Fish Finder properties and also plotters that will automatically steer the boat to destination. I have a Humminbird 998 with Side Imaging and all in HD. Side Imaging gives a 3D image of the bottom structure and objects.
Fishing Sonars, Fish Depth Finders & Chartplotters ' SAIL
https://www.sail.ca/en/fishing/sonars
  1. Cached
LOWRANCE HOOK² 7 Fishfinder with SplitShot Transducer and US / Canada Nav+ Maps. ... HUMMINBIRD HELIX 5 CHIRP GPS G2 With Navionics Card. ... HUMMINBIRD Helix 5 CHIRP DI GPS G2 Sonar With Navionics SD Card.
https://www.google.com/search?q=Depth+finder&sourceid=ie7&rls=com.microsoft:en-US:IE-ContextMenu&ie=&oe=
Boating | Answered on Apr 11, 2019
There is no fuse box, they use inline fuses. Chase the wiring back to the battery, somewhere near the battery or the radio/fish finder will be a fuse on the power wire.
Boating | Answered on Apr 09, 2019
Check for a loose connection or corrosion at the transducer and the unit. Less likely, but bent or broken pin on the connector at the back of the unit. It always works until it doesn't, so that information is of no use.
Boating | Answered on Mar 30, 2019
THEN YOU BOUGHT THE WRONG ITEM . WE KNOW OF NO FIX
Boating | Answered on Mar 29, 2019
12v power is good. Ground is good. Check fuse. If all is good stereo is bad. Check with direct battery 12v and direct battery ground.
Boating | Answered on Mar 20, 2019
Yakima RocketBox Logo
1 questions posted
Top Yakima Boating Experts
ray gallant
ray gallant
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Yakima Boating Expert? Answer questions, earn points and help others
View Most Popular
Yakima Boating
  • Yakima Boating
Most Popular Question
yakima big stack safe fiberglass kayaks
  • Boating
