20 Most Recent
Sony VAIO PCG-TR3AP1 Notebook Questions & Answers
PCG-TR3A PROBLEM! NEED HELP NOW!
I would not take any chances. You might damage it or erase something important. Bring it to a computer center to have them professionally troubleshoot it. They can tell you the cause and how to prevent this from happening again. It may just be a simple fix. It may be worth it to have a piece of mind. Try BestBuy. Good luck!
5/6/2017 9:55:00 AM •
Sony VAIO...
Answered
on May 06, 2017
I want to purchase a
http://shop.ebay.com/i.html?_nkw=sony+vaio+recovery+disc+&_cqr=true&_mPrRngCbx=1&_nkwusc=sony+avio+recovery+disc&_sop=12&_rdc=1
hope it helps
If this helps you resolve your problem, please
consider giving me a rating of 4.It will help me
as well. Thank you.
5/24/2011 12:16:51 PM •
Sony VAIO...
Answered
on May 24, 2011
My laptop comes on, and
If the invertor was faulty you would get a picture on the external monitor, assuming that the external monitor and the laptop was configured to work. Check the Fn key and F5 at the same time. That should switch between internal/ external or both displays.
Hope that helps.
12/9/2010 6:52:30 PM •
Sony VAIO...
Answered
on Dec 09, 2010
Will not boot into windows,just keeps restarting
You have by the description of it, a corrupt boot sector file.
When you boot and it gets to the POST point where entry to the BIOS is displayed, press F8.
I am assuming you run Win Vista or 7.
Choose Recovery from the menu and follow the prompts. As soon as you are in, run CHKDSK/F to fix any errors in the file directories.
Hope that helps.
11/28/2010 4:01:00 PM •
Sony VAIO...
Answered
on Nov 28, 2010
I have a Sony vio
- It smees your LCD is faulty.
- connect your laptop to a external monitor. Check if lines are visible or not.
- if no line are visible then need to change your LCD.
- for changing better to contact service centre.
- you can look for used LCD, which will be cheap.
8/21/2010 6:34:17 PM •
Sony VAIO...
Answered
on Aug 21, 2010
Our sony vaio shuts down for no apparent reason at
you have a corrupted operating system, do this :
turn on your computer press and release F8 few times when you see a menu select "LAST GOOD KNOWN CONFIGURATION"
OR try to perform a restore point, or system restore.
PLEASE RATE ME AND VOTE FOR ME
8/14/2010 8:29:39 PM •
Sony VAIO...
Answered
on Aug 14, 2010
