20 Most Recent Acer TravelMate 273XV PC Notebook Questions & Answers
4answers
Acer Travelmate 270 Memory Upgrade
Acer TravelMate 270 upgrades:
The official upgrade slot is located on the bottom of the laptop and is easy to find. Just unscrew the small cover and there it is.
The other slot requires you to unscrew the two screen bracket screws. Once you have done this, between ESC and F1, F4 and F5 and F12 and PrtSc there are small plastic rings. Put a biro nib into these and pull down. They will pop down. You can now remove the plastic cover.
Unscrew the two screws marked "L9" on the bottom of the laptop which are located at the top of the memory cover. Now you can remove the keyboard. Underneath the keyboard is the second RAM slot. The SiS 650 chipset supports a max of 1GB per memory slot and since this laptop has two slots that means 2GB of RAM. I've used Kingston DDR400 PC 3200 SODIMMS.
You can also upgrade the CPU - the fastest CPU available is the Pentium-M 2.6GHz. Nothing faster will work - trust me on this. It must be a Pentium 4 Northwood architecture CPU with a 400MHz FSB. Standard P4 Northwood CPUs with the metal shim won't fit - unless you know a way of removing the shim without destroying the CPU. Best to stick with a Pentium mobile (Pentium 4 M) chip. Look on Ebay for these.
Of course the hard disk can also be upgraded - a 200GB 7200RPM 2.5" drive works a treat. Non SATA of course.
You can add wireless and USB 2.0 using PCMCIA carbus cards. I use a StarTech 54mbps wireless card with the RAlink chipset and a NEC USB 2.0 card with 4 USB ports. Both cards fit in at the same time.
The laptop absolutely flies with these upgrades.
8/6/2014 5:48:33 PM • Acer TravelMate... • Answered on Aug 06, 2014
2answers
How do I get my laptop to play dvds again it won t work
When you say play DVDs you mean watch DVD movies? Assuming the drive is not broken you need to use the DVD app. You could use VLC Player which you can download. It's an orange traffic cone icon.
9/18/2021 11:29:44 AM • Acer TravelMate... • Answered on Sep 18, 2021
How to fix the black screen on acer travelmate5620 even on the external monitor its doesn't show
Could be it has overheated and the NVidea chip is damaged. No idea why they are called laptops as to put them on a lap blocks the ventilation and they will overheat.
7/20/2021 3:06:30 PM • Acer TravelMate... • Answered on Jul 20, 2021
2answers
My laptop after being turned on a blue screen appears and then shuts down
There are many reasons this can be happening. Try starting the computer in Safe Mode with Networking and see if the problem still exists. If not that means there's a problem with the start up boot process. Questions to consider: How old is the machine? Have you done all your updates? Possible virus. What exactly does the Blue Screen read? Is it a quick blue screen then restarts or does the blue screen stays? We are computer service company that offers remote free diagnosis. Call us to today at (877)608-4574 or visit us at www.aplusonsite.org.
8/22/2017 5:28:34 AM • Acer TravelMate... • Answered on Aug 22, 2017
2answers
HOW DO I DOWNLOAD FACEBOOK ON MY TABLET
I found out in Google that this tablet has Windows 8 on it. You can install Facebook on it by going to the "Microsoft Store". If it didn't install, check if your operating system is 8.1 Let me know if that helps.
1/31/2017 8:11:05 AM • Acer TravelMate... • Answered on Jan 31, 2017
Why will it not turn on
try taking out the battery and unplugging the power cord from it and then holding down the power button for the count of 5 the long way 1 one thousand two one thousand ect.... this will drain back the power from the board and it just might boot after you plug everything back in again and try to power it back on
3/7/2015 3:23:02 AM • Acer TravelMate... • Answered on Mar 07, 2015
Pictures of acer travelmate
https://www.google.com/search?q=acer+travelmate&espv=2&biw=1600&bih=769&source=lnms&tbm=isch&sa=X&ei=BHr3VOfTDJL-gwSMmIG4Bg&ved=0CAcQ_AUoAg
3/4/2015 9:33:08 PM • Acer TravelMate... • Answered on Mar 04, 2015
How do I delete an email address [email protected]
If this is your email address, then you need to log on to Orange.fr website and select delete account.
2/19/2015 12:29:59 PM • Acer TravelMate... • Answered on Feb 19, 2015
How do I find out if I have bluetooth on my laptop
On your laptop go to Control Panel-->Device Manager and then under Network adapters see if you have any Bluetooth Devices install in your laptop. OR Click on the Windows Button and in the Search Box at the bottom type in Bluetooth and see if anything comes up. Eg Turn Bluetooth On.
2/11/2015 4:10:42 PM • Acer TravelMate... • Answered on Feb 11, 2015
How do i unlocked my mini laptop?because its accidentally i locked.canyou pls help me?
You will need to factory restore, this will lose any stored data! 1 Start the Acer Aspire One's operating system. Wait for the Acer logo to appear on the LCD screen. 2 Press the "Alt-F10" keys at the same time to bring up the recovery menu. Press "Enter." 3 Click "Next." Follow the prompts that appear on the screen to restore the operating system back to factory settings. 5 Use the drop-down boxes to select the time zone and language information for your Acer Aspire One. Restart the netbook when you are prompted to finish restoring the computer.
12/27/2014 12:29:41 PM • Acer TravelMate... • Answered on Dec 27, 2014
The speaker icon doesn't bring up the volume controls when i click it. it does nothing, any ideas?
You have problem with your driver, try to reinsall audio driver, first find right driver for your laptop. You can use this tool. http://www.3dpchip.com/3dpchip/3dp/chip_down_en.php Regards.
12/11/2014 1:25:57 PM • Acer TravelMate... • Answered on Dec 11, 2014
Reset to factory settings
Did your computer come with a recovery disc, Windows disc or have you create a recovery set of discs? If after reading all of this you find yourself overwhelmed or unwilling to try, take it to a shop. Another option to the below copied from the Help section to reach the Recovery would be to open the Control Panel. If Category view, under System and Security, select Back up your computer, then Recover system settings, **Then Advanced recovery methods. If in Icon view, select Recovery and you will be at the ** above. There's where the discs above will come into play. If.you don't have any of those, you will have to hope they have a hidden partition on the drive containing the recovery which will either show itself there or in the F8 process below.. To open the System Recovery Options menu on your computer 1. Remove all floppy disks, CDs, and DVDs from your computer, and then restart your computer using the computer's power button. 2. Do one of the following: *If your computer has a single operating system installed, press and hold the F8 key as your computer restarts. You need to press F8 before the Windows logo appears. If the Windows logo appears, you need to try again by waiting until the Windows logon prompt appears, and then shutting down and restarting your computer. *If your computer has more than one operating system, use the arrow keys to highlight the operating system you want to repair, and then press and hold F8. 3. On the Advanced Boot Options screen, use the arrow keys to highlight Repair your computer, and then press Enter. (If Repair your computer isn't listed as an option, then your computer doesn't include preinstalled recovery options, or your network administrator has turned them off.) 4. Select a keyboard layout, and then click Next. 5. On the System Recovery Options menu, click a tool to open it.
    • If your computer has a single operating system installed, press and hold the F8 key as your computer restarts. You need to press F8 before the Windows logo appears. If the Windows logo appears, you need to try again by waiting until the Windows logon prompt appears, and then shutting down and restarting your computer.
    • If your computer has more than one operating system, use the arrow keys to highlight the operating system you want to repair, and then press and hold F8.
12/7/2014 3:53:00 PM • Acer TravelMate... • Answered on Dec 07, 2014
Problem playback device skype
Reinstalling the Skype could be cure the problem.
8/28/2014 11:52:59 AM • Acer TravelMate... • Answered on Aug 28, 2014
Acer TravelMate 273XV PC Notebook Logo
Popular Tags
1 questions posted
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
TravelMate Acer
  • TravelMate Acer
Most Popular Question
acer travelmate 270 memory upgrade
  • Computers & Internet
