20 Most Recent Sony CRX830E CD-RW/DVD-ROM (Combo) Burner Questions & Answers
0answers
My cdrom makes noise when i insert dvd
What type of noise does it make? If you hear the tray close and then the disc "spin" for a minute or so, that is normal. If it sounds like something is shaking or rattling or lasts more than 5 minutes, there is probably something wrong.If it is an extended spin noise, the drive isn't recognizing the disc. Check if there are scratches and try another disc. If you hear a shaking or rattling, do not use the drive. It's probably better to replace the drive (check if it is under warranty - usually 1 year). This drive has an IDE connection. You will need to check your motherboard specifications to identify if you can replace the drive with a SATA optical drive (more common now) or if you need to find an IDE drive. (Note: OEM drives do not ship with the data cables or software discs, this will matter if you get a SATA drive.)Some optical drives have a problem with the magnet that holds the disc for the laser to hold it. Some people fix this problem with duct tape; at <$20 for a SATA DVD-RW OEM drive, it isn't worth my time to fix. I hope this helps. Please add a comment describing your sound and the computer you have for additional help.Cindy Wells
12/26/2012 11:35:48 PM • Sony CRX830E... • Answered on Dec 26, 2012
THE DVD TRAY NOT OPENIG
make sure that the cd rw/dvd rom is getting enough power test all leads that are attached to the dvd including electrical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back in this should activate the found new hardware wizard you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device click start control panel administrive tools,computer management device manager scroll down cd dvd rom drives if you see a yellow question mark? right click to update driver select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstallhope this helps you
8/1/2011 6:58:22 PM • Sony CRX830E... • Answered on Aug 01, 2011
The system dose not work
make sure all leads that are attached to your cd/dvd have secure connections and are not faulty or just replace them they could be faulty ? you might have to physically unplug the cd/dvd drive restart your computer this should activate the found new hardware wizard Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer Close all open programs
Click on Start, Run, and type regedit and press Enter Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.hope this helps
5/30/2011 7:31:54 PM • Sony CRX830E... • Answered on May 30, 2011
2answers
My CD-RW drive says it
You cannot fix this you will need a new one. They are not that expensive and easy to replace. One screw on the bottom of the lap top and it pulls out you are done. Or you can leave it and purchase a external burner USB style many people do this as well. I hope this assisted you. John
1/28/2011 5:18:07 PM • Sony CRX830E... • Answered on Jan 28, 2011
Code 41 error
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
1/17/2011 9:25:48 PM • Sony CRX830E... • Answered on Jan 17, 2011
What type of disc does a sony crx830e support
This is a combo drive
It will support
1. CD reading & burning (Blank CDR and CDRW)
2. DVD reading only.
We cannot use a combo drive to burn DVD.
1/2/2011 7:35:25 PM • Sony CRX830E... • Answered on Jan 02, 2011
0answers
No lee nada
Be the first to answer 12/2/2010 10:51:52 PM • Sony CRX830E... • Posted on Dec 02, 2010Be the first to answer
I have a Sony DVD
make sure that the cd-rw/dvd-rom burner is getting enough consistent power test all leads that are attached to the cd-rw/dvd-rom burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty
hope this helps
12/2/2010 6:02:23 AM • Sony CRX830E... • Answered on Dec 02, 2010
Wont read cd's
You could either pay $50 for a qualified technician to "trouble-shoot", and still not fix it, or you could pay $40 to $50 to buy a brand-new CD/DVD reader/writer. Your choice?????
8/27/2010 12:44:57 AM • Sony CRX830E... • Answered on Aug 27, 2010
When I want to burn there is a notice :This cd is
try to usean empty & blank disk for write.then start burning.if i couldnt write again,u must re install ur software or update it.
8/11/2010 11:09:52 AM • Sony CRX830E... • Answered on Aug 11, 2010
My computer can see my drive but can not read the
check your BIOS setup and reinstall the your bootable drive
3/18/2010 7:59:35 AM • Sony CRX830E... • Answered on Mar 18, 2010
Can't read all kind of dvd..
hi,, there are different kinds of DVDs ,, some are DVD+R , DVD-R ,,and dual layered dvds so.. please check the details for support of dvd , cd drive...
9/27/2009 3:56:18 PM • Sony CRX830E... • Answered on Sep 27, 2009
NOT BURNING
Try to check if your DVD/CD ROM is properly attach and also try to check your Disk also if this disk is detected by your Writer.
6/26/2009 11:07:25 AM • Sony CRX830E... • Answered on Jun 26, 2009
Where can i get driver
use things like driving detective or something. it automatically gives you updates for your hardwares that needs updates
5/20/2009 4:38:12 AM • Sony CRX830E... • Answered on May 20, 2009
The process Enabling the Taskmanager
"procexp.exe" download from Microsoft
1/18/2009 5:24:29 PM • Sony CRX830E... • Answered on Jan 18, 2009
2answers
Not reading DVD
It's common problem with combo drives in notebooks, they don't seem to last long. Try this:- Go to my computer>properties>hardware>device manager and look down the list for your cd/dvd drives and click the '+' sign then highlight your dvd drive and right click to delete. Restart the pc and windows will find the drive again automatically and install the drivers. If the problem persists the laser is faulty in the drive and the drive will need to be replaced.
11/30/2008 8:05:24 PM • Sony CRX830E... • Answered on Nov 30, 2008
0answers
Sony MHC-vx888 turn volume up sound disconnect
the capacitors in side on the amp have gone weak. it has noticed the fault and is telling you. check the capacitors look for any sight of problems look for the end being popped up and brow-black gunk on the board around them tackie to the touch and change them. also give the boards a good clean out using a new paint brush sweep the dust out.
10/20/2013 2:05:40 AM • Sony CRX... • Answered on Oct 20, 2013
Sony CRX830E CD-RW/DVD-ROM (Combo) Burner Logo
24 questions posted
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
CRX Sony
  • CRX Sony
Most Popular Question
when want burn notice cd
  • Computers & Internet
