20 Most Recent
Magic Chef 11.8 cu. ft. / 334 liter Upright Freezer CFU1236GRW Questions & Answers
We defrosted our upright magic
I have the same problem, but so far, I have no resolution to the problem. My model however; is MCUF88W. There is a 1-888-775-0202 telephone number, but when I called, there is a busy tone. I need a solution to the problem.
The freezer is only two years for crying out loud. No solution here, SORRY. HELP!!!!!!!!
Bought new 8.8 stand up magic c freezer can't get
Bought the same freezer from Home Depot, door would not open did find with a bit of detective work that if you place your fingers between the door gasket and the shell of the freezer you can break the glue type seal then door works fine. You must go across top and down both sides.
MAGIC CHEF FREEZER THE DOOR IS NOT OPENING FOR 8.8
If You run Your finger in between the rubber seal that is resting on the freezer and the frame of the door , the rubber seal will break lose. When you open the door the seal is attache to the door.
Just had the same problem after unboxing.
Simple, just be sure to do the entire door.
Just quit working.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong.
If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
