20 Most Recent Magic Chef CTB1722 Top Freezer Refrigerator Questions & Answers
Hi i have a magic chef model # mcbr 1010b it was
Since you left door open I think the evaporator is frozen up .Just shut it off for a while and let everything defrost then turn it back on and you should be fine
1/5/2018 1:54:35 AM • Magic Chef... • Answered on Jan 05, 2018
0answers
0answers
Fridge is not cooling properly
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If
you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
8/24/2011 1:33:18 AM • Magic Chef... • Answered on Aug 24, 2011
Freeze's up
That is going to be a problem with one of the components in the automatic defrost system. It is supposed to automatically defrost. Turning it off overnight to melt it will defiently help. If you are mechinacally inclined here is what to check.
DEFROST HEATER ...remove back wall of freezer and you will see a black heater at the bottom of the coil thats frosted up,it looks similar to the bake element in your oven,or in some cases it is going to be a spiraled wires inside of a glass tube. To check it,use a multimeter set to the lowest ohms of resistiance setting and follow and find the wires at the top of that frosted coil,unplug/disconnect those wires and check for continuty with around 5-20 ohms of resistiance. If it has that amount of ohms the heater is good. If your meter display does not change or displays OL the defrost heater is broke and needs to be replaced
DEFROST TERMINATION THERMOSTAT... it's round and has 2 wires and clips to the top of that frosted up coil. IT MUST BE CHECKED WHEN COLD SO BEST TO DO WHEN FROST IS STILL BUILT UP. To check it disconnect the wires on it and check for ZERO ohms of resistiance. As with the heater if the meter display OL or doesnt change,it is the problem
DEFROST CONTROL...it is hard to check for a semi unskilled person and if the heater or defrost t-stat check good its going to be the problem. It will NOT be in the freezer it could be on back wall or inside the control panel in the refrigerator section.
Good luck,
Gene
8/14/2011 4:22:55 PM • Magic Chef... • Answered on Aug 14, 2011
My freezer is on one of the coldest settings, but
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
8/13/2011 3:18:18 AM • Magic Chef... • Answered on Aug 13, 2011
A while back the refrigerator was freezing
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
7/27/2011 11:35:43 PM • Magic Chef... • Answered on Jul 27, 2011
0answers
Lots of water accumulates in tray under
You have an auto defrost drain line that is plugged up.Look behind the light and control shield in the fresh food section of your refrig., you should be able to see the problem.If you can not clean the line out from that point then you may have to move the refrig. out from the wall and get to it from there. I hope this helps and Thank You for using Fix ya
6/22/2011 11:37:03 PM • Magic Chef... • Answered on Jun 22, 2011
Hi. My Magic Chef refrigerator ctb1722arw is not
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
6/12/2011 8:14:42 PM • Magic Chef... • Answered on Jun 12, 2011
The freezer is working fine
Have you checked the refrigerator settings? Should have 2 setting controls 1 for frig and 1 for freezer
5/27/2011 1:12:58 PM • Magic Chef... • Answered on May 27, 2011
Model #CTB1821ARW - I have
It sounds like the "Duct" adjustment may be set wrong.
There should be "Two" different dials on your unit. One is the actual thermostat, which senses the "refrigerator" temp only. The other is a duct from the freezer compartment to the refrigerator.
If this is the problem, simply turn the (refrigerator knob to a colder setting). Yo May also have the "outlet" for the duct seriously blocked., If so just move your product (in the fridge).
Hope this is it, there a a few other possible solutions, but from your description these are the most probable.
5/12/2011 6:27:48 PM • Magic Chef... • Answered on May 12, 2011
Magic Chef CTB1722 Top Freezer Refrigerator Logo
Popular Tags
56 questions posted
Top Magic Chef Refrigerators Experts
Kardoc
vince
Paul Carew
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Magic Chef Refrigerators
Most Popular Question
magic chef refrigerator ctb1722arw not
  • Refrigerators
