20 Most Recent
Lenoxx Electronics CD-88 Personal CD Player Questions & Answers
Hello, i need an owners
My model CD-88 programmable compact disc player player will go around but no music comes from it. It is one that you can use in your car tape player as it has an adapter. What is wrong with it ? Thank you. Estella Huffman
[email protected]
10/29/2018 6:30:31 AM •
Lenoxx...
Answered
on Oct 29, 2018
The cd player do not spin it comes on then go off
HelloThe sled motor of your player is not working. This is the motor that spins the disc inside as soon as it has been loaded. But to spin disc, the disc must be loaded properly into the loading mechanism. Just check the loading belt that attached with loading motor and loading gear set for any loose, which may cause improper disc loading. Replace it first. If it does not help you, check the voltage at the seled motor terminals. There must be a voltage [4.5VDC approx:]. If the voltage is there and still the sled motor does nor work, replace it. If voltage is not there, the fault is with the loading IC which is soldered to the main board of the device. OK>
1/29/2023 5:25:17 PM •
Lenoxx...
Answered
on Jan 29, 2023
No shuffle on model MP3-8700S
if the problem came from the factory it may be unavailable for the model ...but also can be just a software issue ..and updating the firmware can fix it ..Remember that updating firmware is a 2 way street ..and can cause good ..and loose some functions in the same time ..so ..think twice before proceed with it ..If it works good..I would not make it unless is a have to do it matter ..
The firmware can be downloaded from the support site of the manufacturer..
1/20/2011 4:50:36 AM •
Lenoxx...
Answered
on Jan 20, 2011
I have a model CD-102
I will advice you check either of any of this two sites amazon.com or ebay.com to get the replacement part you need for your device.
Take care.
9/4/2010 8:07:09 PM •
Lenoxx...
Answered
on Sep 04, 2010
How do I change to degree mode on my porpo YH-2000
- Power Off: Turn off the device.
- Jumper Configuration: Locate the jumper labeled "S16" on the device. Initially, it should be connected to pins 2 and 3.
- Power On (Alarm+All LEDs Flashing): Turn the device back on. You'll see the alarm LED and all other LEDs flashing.
- Power Off Again: Turn off the device once more.
- Jumper Adjustment: Change the jumper configuration from pins 2 and 3 to pins 1 and 2.
- Finished: Your Porpo YH-2000 is now set to the desired angular unit mode.
If you encounter any issues, you can press the reset switch on the back of the device to reinitialize it.
Openfit Shokz battery replacement?
Question edited for clarity, typo and CAPS.
Question moved from Cars and Trucks category.
Claim on the warranty irrespective of how long you have had them. They charge $180 but they cost them $20 to buy from China. Package them up and send them tracked and ask them to replace the batteries.
How long is the warranty on AfterShokz?
While we hope you never need it, all new Shokz purchased from authorized retailers come with a two-year warranty that begins on your date of purchase.
Jan 11, 2019
https://www.google.com/search?q=Openfit+Shokz+battery+replacement
