20 Most Recent
Lenoxx Electronics CD-50 Personal CD Player Questions & Answers
My portable cd player is acting weird all of a sudden! HELP!!!!
You need to open it up to check the parts inside. First look around to see if there is any plastic parts that are damaged. This might account for the noises inside. If you can not see anything wrong. Get a magnifying glass or lens and look at the lazer lens. Make certain the power is NOT on for any of these tests. If you see any odd light patterns or damage on the lazer lens it will not play discs. Unless it was an expensive model it will not be worth repairing if the lens is damaged. Do not open the unit if the model is still under warranty. In which case contact the maker of the unit.
5/5/2017 6:06:46 PM •
Lenoxx...
Answered
on May 05, 2017
Player turns on but no
Please try to put in an ordinary audio CD track and see if this is detected. If yes the optical is working, if not there is no laser scanning and the possibility of the head being faulty is high.
Now certain cleaner disks are not read and so will not be tracked. Hence it is best for cleaning manually the laser head eye with a cotton bud very softly and without any pressing of the lens eye.
If there is still no result then watch the CD if it spins or tries to spin. If the head unit moves up or down to focus or in and out of the drive, if so the board seems to work correctly and the possibility of the optical head being the suspected fault is very high.
12/17/2010 4:08:17 PM •
Lenoxx...
Answered
on Dec 17, 2010
The cd player do not spin it comes on then go off
HelloThe sled motor of your player is not working. This is the motor that spins the disc inside as soon as it has been loaded. But to spin disc, the disc must be loaded properly into the loading mechanism. Just check the loading belt that attached with loading motor and loading gear set for any loose, which may cause improper disc loading. Replace it first. If it does not help you, check the voltage at the seled motor terminals. There must be a voltage [4.5VDC approx:]. If the voltage is there and still the sled motor does nor work, replace it. If voltage is not there, the fault is with the loading IC which is soldered to the main board of the device. OK>
1/29/2023 5:25:17 PM •
Lenoxx...
Answered
on Jan 29, 2023
No shuffle on model MP3-8700S
if the problem came from the factory it may be unavailable for the model ...but also can be just a software issue ..and updating the firmware can fix it ..Remember that updating firmware is a 2 way street ..and can cause good ..and loose some functions in the same time ..so ..think twice before proceed with it ..If it works good..I would not make it unless is a have to do it matter ..
The firmware can be downloaded from the support site of the manufacturer..
1/20/2011 4:50:36 AM •
Lenoxx...
Answered
on Jan 20, 2011
I have a model CD-102
I will advice you check either of any of this two sites amazon.com or ebay.com to get the replacement part you need for your device.
Take care.
9/4/2010 8:07:09 PM •
Lenoxx...
Answered
on Sep 04, 2010
How do I change to degree mode on my porpo YH-2000
- Power Off: Turn off the device.
- Jumper Configuration: Locate the jumper labeled "S16" on the device. Initially, it should be connected to pins 2 and 3.
- Power On (Alarm+All LEDs Flashing): Turn the device back on. You'll see the alarm LED and all other LEDs flashing.
- Power Off Again: Turn off the device once more.
- Jumper Adjustment: Change the jumper configuration from pins 2 and 3 to pins 1 and 2.
- Finished: Your Porpo YH-2000 is now set to the desired angular unit mode.
If you encounter any issues, you can press the reset switch on the back of the device to reinitialize it.
