20 Most Recent NetTV DTV34XF3 34" TV Questions & Answers
Sounds as though you have a leaking Capacitor in the horizontal section. The problem capacitor is likey to be orage in color and rated at 2kv or higher. Located next to the High Voltage transformer ( Flyback transformer ). Be very cautious if you are changing this, or any part yourself as the picture tube can charge high voltage ( up to 35,000 volts ) for a long period of time. Always discharge the picture tube first before servicing a set.
Replace the capacitor with a like part with the same or higher voltage rating and the same capacitance number ( mfd, pfc,or such ) as listed on the side of the part.
Good Luck
Ed
NC Electronic
Mills, Wyoming
NetTV DTV34XF3... | Answered on Jan 24, 2008
Hi Chandra,
The price on this product looks like a bargain to me. Although you have noticed many problems from users on this set, you will see problems on any set, so I would doubt the problems you are seeing are of a quanity that should not be of any concerns.
Good luck on your purchase.
Ed
NC Electronic
Mills, Wyoming
well what sounds like happened is you blew up the tube in it. have you unplugged it from the wall and just let it sit some times that helps because what will happen is there will be a Electrical build up and it won't work right. an other thing you might want to do is hit the Degauss button on the remote. plug some sort of video signal into it and go through the inputs to see if that helps, mine did that every thing would just be black but i plug in my video camera it would detect it and make sure that the audio cables are plugged in these TV might just be that old that they have to have both audio and video in order to work.
NetTV DTV34XF3... | Answered on Dec 22, 2007
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Televison &... | Answered 3 hours ago
get a universal remote from Wal-Mart or order one
Televison &... | Answered 5 hours ago
plase tapon the crosslines firmly the crosslines will continue to move until the screen is aligned
Check whether audio is muted by accendiantial press on remote control. Then Check its speaker. If it is alright, the audio output IC of your set might be damaged. If you wish to get some details; visit the site linked here. Pull up older posts.
https://electronicshelponline.blogspot.com/
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. See the site by a desktop. Mobile view has no search box. If you are viewing it by your mobile, see it in webview.]
Televison &... | Answered 8 hours ago
Sounds like laser pickup unit fault. Contact any service technician. This is not a user repairable fault. If you wish to get some details; visit the site linked here. Pull up older posts.
I don't think the people trying to solve this even understand the issue, it won't turn on! How can someone do any of these suggestions where it won't go last the starting mode? So now that you understand the issue try providing another answer. Philips site is useless on anything, that won't even post these systems in their searches.bthey show a bunch of files to download but nothing that mentions the huge problem of so many if their products stuck at starting. Everyone already knows that Philips makes complete junk but for some reason people still buy it or they wouldn't be making anything anymore.
Between Philips and Samsung I'm not sure who uses less metal in their products, everything they make is 99% plastic and uses the cheapest components with the thinnest copper traces on their boards making repairs difficult.
I looked at the components and can't find any obvious bad or burnt items, usually there's a bad capacitor that causes this, but not this time. I suspect it a fatal software error that's not allowing it to start the system. I looked at the Blu-ray laser and it's not even getting power to it at all. So the system has power but the operating system is not starting. It's trying to load and is simply corrupt. Similar to when your computers operating system cannot start. It will just sit there and show a start up screen but never loads and you can't do anything not even turn it off unless you flip the switch or hit reset. I have to unplug mine, if if hit the power button it doesn't do anything or it says standby and won't do anything, it won't even turn off, it just stays on standby and the red light won't even light on the power switch. The light turns red when it's unplugged and back in, then green when it's powered up, then it immediately says STARTING, I left it sit for 30 minutes and it won't do anything. It's junk! Without the ability to reload a new copy of the software there's nothing we can do except stop buying Philips garbage no matter how cheaply they're priced. I would say you get what you pay for but that's simply not true when there are companies like Samsung selling junk at rediculuos prices and people are rushing out to throw their money away. If you disagree with my take on either Philips or Samsung, just wait, you haven't owned it long enough yet to find out how short lived (keep in mind I'm still using an old pioneer premier 7.1 THX 120wpc receiver made in 2003 and a mitsubushi 48" LCD HD TV with the original bulb 10 hours a day use since 2007, Samsung will never last even 5 years) they are and difficult to operate and even more impossible to repair, most issues are software related. I'll bet 90% of functions go unused on Samsung just because nobody has time to try and figure out how to even set them up let alone use it.
Televison &... | Answered 9 hours ago
After unplugging the tv, hold and press the physical power button on your tv for about 30 seconds, that will drain most of the electricity stored in most of the motherboards components, however some energy will be stored in some capacitors; mainly on the power supply side but eventually they also will be depleted of it as well as time goes by.
to answer your question, it's a low risk repair .
Televison &... | Answered 11 hours ago
you believe the ones that make it work
How to Connect Your Android Tablet to a TV with an HDMI ...
https://www.dummies.com > consumer-electronics > how-to-connect-your-...
You may think that having a 10-inch Android tablet really smokes those folks with the smaller, 8-inch tablets. Ha! You're in for a surprise. That's because any ...
Televison &... | Answered 17 hours ago
What Is Schizophrenia? - American Psychiatric Association
https://www.psychiatry.org > patients-families > what-is-schizophrenia
Schizophrenia is a chronic brain disorder that affects less than one percent of the U.S. population. When schizophrenia is active, symptoms can include delusions, hallucinations, trouble with thinking and concentration, and lack of motivation. ... Positive psychotic symptoms ...
Schizophrenia - Symptoms and causes - Mayo Clinic
https://www.mayoclinic.org > symptoms-causes > syc-20354443
Apr 10, 2018 - Schizophrenia is a serious mental disorder in which people interpret reality abnormally. Schizophrenia may result in some combination of hallucinations, delusions, and extremely disordered thinking and behavior that impairs daily functioning, and can be disabling.
Learn about what is schizophrenia and schizophrenia ...
https://www.schizophrenia.ca > learn_more_about_schizophrenia
Schizophrenia is a serious mental illness that affects 300,000 Canadians. ... Psychosis (psyche = mind, osis = illness) is defined as the experience of loss of contact with reality and usually involves hallucinations and delusions. ... Schizophrenia treatment professionals must rule out ... ‎Diagnosing Schizophrenia · ‎The Symptoms of ... · ‎Causes · ‎Schizophrenia and Co ...
Televison &... | Answered 18 hours ago
NetTV DTV34XF3 34" TV Logo
4 questions posted
Popular Products
Top NetTV Televison & Video Experts
Ekse
Are you a NetTV Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • NetTV Televison & Video
Most Popular Question
thinking buying tv brand new
  • Televison & Video
