20 Most Recent
NetTV DTV-29XF3 29" TV Questions & Answers
My LG Super Slim 29"
You don't have a deflection yoke problem, you have a pin cushion problem. Check the pin cushion transistor.
No vertical deflection
Never heard of this model/make. Must be a label TV How many pins and whats it start with ie TA-LA?
Where is the Google on the Matertech?
It appears that there could be miscommunication. As of my previous update in January 2022, Matertech doesn't seem to be a commonly known term or corporation. On the other hand, if you're talking about "Google," it's a well-known worldwide technological corporation that specializes in internet-related services and goods, such as search engines, cloud computing, online advertising technologies, software, and hardware.
Google's official website or an internet search utilizing one of the search engines like Google itself are usually the easiest ways to get information about Google. If "Matertech" relates to a particular thing or idea, further information could be helpful in order to provide a more precise answer.
How do I download Showmax on my Sinotec STL-55G50 smart tv
- Turn on your Smart TV: Ensure your Sinotec TV is powered on and connected to the internet.
- Navigate to the App Store: Look for an app store or marketplace on your TV's home screen. It might be called something like "App Store," "Google Play Store," or "Smart Hub."
- Search for Showmax: Use the search function within the app store to search for the Showmax app. You can usually find this by typing "Showmax" into the search bar using your TV remote.
- Select and Install the Showmax App: Once you've located the Showmax app in the app store search results, select it, and then choose the option to install or download it to your TV.
- Open the Showmax App: After the installation is complete, navigate back to your TV's home screen and locate the Showmax app icon. Select it to open the app.
- Sign In or Sign Up: If you already have a Showmax account, sign in using your credentials. If not, you may need to sign up for a Showmax account using your email address and creating a password.
- Start Watching: Once you're signed in, you should be able to start browsing and watching content on Showmax.
- Hope this helps
15.6 hiteker LCD TV low sound
The sound bar on this TV can go up to around 60, but users typically keep it between 19-23.
To enhance the sound on your Hiteker TL50Z10AH-TP TV, consider the following options:
External Speakers or Soundbar:
Connect external speakers or a soundbar to your TV. These devices often provide better sound quality and volume compared to built-in TV speakers.
Look for a soundbar with adjustable bass and treble settings to fine-tune the audio to your liking.
Audio Settings:
Explore the TV's audio settings menu. You might find options to adjust the sound mode (e.g., Standard, Music, Movie, Sports), equalizer settings, and virtual surround sound.
- Audio Output:
- If your TV has anaudio output(such as anopticalor3.5mm headphone jack), connect it to an external amplifier or a set of powered speakers.
- Adjust the volume on both the TV and the external device to achieve the desired sound level.
- Positioning and Acoustics:
- Ensure that the TV isnot obstructedby any objects or furniture. Clear space around the built-in speakers for better sound projection.
- Consider placing the TV on asound-absorbing surface(e.g., a soft mat or carpet) to improve acoustics.
- Universal Remote with Volume Boost:
- If you're using a universal remote, check if it has avolume boostfeature. Some remotes allow you to increase the volume beyond the TV's default limit.
Hi there, I cannot play
Region 1 DVD's will NOT play on region 2 dvd players.
You need either a region 2 disk or a region 1 DVD Player.
