20 Most Recent GE EasyCam Pro Webcam Questions & Answers
0answers
Need webcam driver
Click start control panel view devices and printers you should see your webcam from there if you are have trouble with your webcam Click start control panel administrative tools computer management device manager scroll down image devices you could see a yellow question mark? right click to reinstall drivers or update driver xp Click start right click on computer select properties device manager scroll to image devices expand right click to update driver in W7 http://download.cnet.com/2000-20_4.html on the home page you should see a search tab just type in what you are looking for IE: webcam name webcam driver you might have to try a few times to get it right software if you dont have the driver you will need to download one here rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8 It might take some time being a freeware driver solution note: it will find all of your outdated drivers this is a free driver solutions This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point click no to both of these then continue updating each driver free then restart once all of the drivers have been updated Some webcams and programs require additional software, although that should be installed with the webcam if things are right. But is does not harm to check if your Java, Flash and Quicktime software are installed and up to date. But certainly check your DirectX software, since all video applications, including webcams, use DirectX for video processing. Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c - Windows Vista: DirectX 10). http://windows.microsoft.com/en-US/windows7/Which-version-of-DirectX-is-on-your-computer If you still have no webcam installed Run the "Add a device"application, accessed by clicking on the "Start" button, opening the "Control Panel," and then double-clicking on "Add a device." The "Add a device" window will open and Windows will search for devices connected to your system but not installed. Click on the webcam name that shows in the search box and then click "Next." Choose whether you want Windows to search for the webcam device driver using Windows Update over the Internet, or if you'd prefer to have the device manager search for the driver using a disc supplied by your laptop manufacturer. Most drivers can be found on the system recovery disc included with your laptop, if you choose to add the driver from the provided disc. Place a check in the box next to your choice and then click "Next>" to continue. Wait while Windows searches from the driver using Windows Update, if this was your choice. An active Internet connection is required for Windows to successfully do this. Allow the computer to install the driver and then reboot the system for the webcam to become recognized by the system. Otherwise, you can use the system recovery disc or a driver downloaded directly from your laptop manufacturer to install the driver without using the Windows Update search feature. Open the CD/DVD-ROM drive and insert the system recovery disc, or place the driver downloaded from the manufacturer in an easily accessed file directory on your PC, such as on the desktop, or in your "My Documents" folder. Choose the option "Install the software automatically (Recommended)" in the "Add a device" application, and press "Next>" to begin searching for your webcam driver. The hardware wizard will search the system recovery disc and install the driver automatically. Press "Finish" to close the wizard and then reboot the computer to allow recognition of the webcam. Choose the option "Install the software manually" in order to browse to the driver location where you saved the driver and install it from there. Use the opened file manager and locate the driver. Click the "Next>" button to install the driver, then reboot the computer to add webcam functionality.
4/6/2013 10:56:30 PM • GE EasyCam Pro... • Answered on Apr 06, 2013
I need drives sor m easycam pro
please download link below for webcam driver
http://www.driverfiles.net/Cameras/Chicony-Electronics/GE-HO98064/download/page,sh,17174,40,17,.html
Please rate the answer positively, it will give me some satisfaction to know am helping some one so I will keep on helping.
Thanks for using fixya
1/18/2013 11:23:02 PM • GE EasyCam Pro... • Answered on Jan 18, 2013
Need a working driver for ho98064 for win 7 (64 bit)
Click start control panel view devices and printers you should see your webcam from there if you are have trouble with your webcam Click start control panel administrative tools computer management device manager scroll down image devices you could see a yellow question mark? right click to reinstall drivers or update driver xp Click start right click on computer select properties device manager scroll to image devices expand right click to update driver in W7 http://download.cnet.com/2000-20_4.html on the home page you should see a search tab just type in what you are looking for IE: webcam name webcam driver you might have to try a few times to get it right software if you dont have the driver you will need to download one here rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8 It might take some time being a freeware driver solution note: it will find all of your outdated drivers this is a free driver solutions This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point click no to both of these then continue updating each driver free then restart once all of the drivers have been updated Some webcams and programs require additional software, although that should be installed with the webcam if things are right. But is does not harm to check if your Java, Flash and Quicktime software are installed and up to date. But certainly check your DirectX software, since all video applications, including webcams, use DirectX for video processing. Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c - Windows Vista: DirectX 10). http://windows.microsoft.com/en-US/windows7/Which-version-of-DirectX-is-on-your-computer Hope this helps.
1/18/2013 7:59:24 PM • GE EasyCam Pro... • Answered on Jan 18, 2013
I need driver
1st You download Webcam Driver.I need driverAfter this install the Webcam driver in the system.Installation of Webcam DriverGo to the control panelClick on the System IconClick on the Hardware TabClick on the Device Manager sSelect the Unknown Device or printer device where yellow Question Marks sign on it.Right click on it and uninstall it.After this go to the top of the device manager and click on scan for hardware changes.Driver installation Wizard start.Brows Your Driver from the Hard Disk and click on next.Driver will be install.
12/14/2012 5:56:52 PM • GE EasyCam Pro... • Answered on Dec 14, 2012
Microsift x13-51170-01 need software to install
1st You download Webcam Driver.Microsift x13-51170-01 need software to installAfter this install the Webcam driver in the system.Installation of Webcam DriverGo to the control panelClick on the System IconClick on the Hardware TabClick on the Device Manager sSelect the Unknown Device or printer device where yellow Question Marks sign on it.Right click on it and uninstall it.After this go to the top of the device manager and click on scan for hardware changes.Driver installation Wizard start.Brows Your Driver from the Hard Disk and click on next.Driver will be install.
12/14/2012 5:38:05 PM • GE EasyCam Pro... • Answered on Dec 14, 2012
Drivers and softward wont install with CD
1st You download Webcam Driver.Drivers and softward wont installAfter this install the Webcam driver in the system.Installation of Webcam DriverGo to the control panelClick on the System IconClick on the Hardware TabClick on the Device Manager sSelect the Unknown Device or printer device where yellow Question Marks sign on it.Right click on it and uninstall it.After this go to the top of the device manager and click on scan for hardware changes.Driver installation Wizard start.Brows Your Driver from the Hard Disk and click on next.Driver will be install.
8/17/2012 4:58:28 PM • GE EasyCam Pro... • Answered on Aug 17, 2012
Need drivers or softwhere for easy cam pro mn
1st You download Webcam Driver.drivers or softwhere for easy cam pro mn 98669After this install the Webcam driver in the system.Installation of Webcam DriverGo to the control panelClick on the System IconClick on the Hardware TabClick on the Device Manager sSelect the Unknown Device or printer device where yellow Question Marks sign on it.Right click on it and uninstall it.After this go to the top of the device manager and click on scan for hardware changes.Driver installation Wizard start.Brows Your Driver from the Hard Disk and click on next.Driver will be install.
8/17/2012 4:56:25 PM • GE EasyCam Pro... • Answered on Aug 17, 2012
I need a driver for my GE 1250 TW digital camera that will download onto my I Mac
1st You download Webcam Driver.driver for my GE 1250 TW digital cameraAfter this install the Webcam driver in the system.Installation of Webcam DriverGo to the control panelClick on the System IconClick on the Hardware TabClick on the Device Manager sSelect the Unknown Device or printer device where yellow Question Marks sign on it.Right click on it and uninstall it.After this go to the top of the device manager and click on scan for hardware changes.Driver installation Wizard start.Brows Your Driver from the Hard Disk and click on next.Driver will be install.
8/17/2012 4:54:58 PM • GE EasyCam Pro... • Answered on Aug 17, 2012
Need GE easycam pro software for model #98669
1st You download Webcam Driver.GE easycam pro software for model #98669After this install the Webcam driver in the system.Installation of Webcam DriverGo to the control panelClick on the System IconClick on the Hardware TabClick on the Device Manager sSelect the Unknown Device or printer device where yellow Question Marks sign on it.Right click on it and uninstall it.After this go to the top of the device manager and click on scan for hardware changes.Driver installation Wizard start.Brows Your Driver from the Hard Disk and click on next.Driver will be install.
8/17/2012 4:53:38 PM • GE EasyCam Pro... • Answered on Aug 17, 2012
I need the software for my ge easy cam
1st You download Webcam Driver. software for my ge easy camAfter this install the Webcam driver in the system.Installation of Webcam DriverGo to the control panelClick on the System IconClick on the Hardware TabClick on the Device Manager sSelect the Unknown Device or printer device where yellow Question Marks sign on it.Right click on it and uninstall it.After this go to the top of the device manager and click on scan for hardware changes.Driver installation Wizard start.Brows Your Driver from the Hard Disk and click on next.Driver will be install.
8/17/2012 4:52:20 PM • GE EasyCam Pro... • Answered on Aug 17, 2012
Need to install ge easycam
Jasco products takes care of GE consumer electronics.Windows 95, 98, 2000, & XP:http://www.jascoproducts.com/support/software-downloads.asp#pccamsWindows 7:http://www.jascoproducts.com/support/software-downloads-win7.asp
9/19/2011 4:58:46 AM • GE EasyCam Pro... • Answered on Sep 19, 2011
0answers
Hi! I have a webcam
Ok it isn't unusual for a CD ROM or DVD ROM to not recognize a CD or DVD insert to it..Ok try this clean the lenses of your ROM using a CD or DVD cleaner disc if you have also try to wept your cd software with a clean dry soft cloth or cotton..If this will not work perhaps you need a new installation cd for your webcam.
7/10/2011 12:13:25 PM • GE EasyCam Pro... • Answered on Jul 10, 2011
GE EasyCam Pro Webcam Logo
159 questions posted
Top GE Computers & Internet Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Are you a GE Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
EasyCam GE
  • EasyCam GE
Most Popular Question
microsift x13 51170 01 need software
  • Computers & Internet
