20 Most Recent HP A6795A#0D1 Network Adapter Questions & Answers
Driver for the nic card in a hp dv6 notebook
http://www8.hp.com/us/en/support-drivers.htmlGo here. Enter your model number. Select Windows 7 64 bit and download the driver.
12/25/2012 12:32:53 AM • HP A6795A#0D1... • Answered on Dec 25, 2012
The network adapter 6to 4 #2 is missing in the device mrg.
yeah this sounds to me like a driver issue now i don't know if your using the device driver if your using a windows driver then turn of the pc remove the device and then remove the driver then install the proper device driver then the device hopew this helps if not let me know and ill try to help more
5/15/2010 9:00:15 PM • HP A6795A#0D1... • Answered on May 15, 2010
My compaq laptop adaptor starts to not work and it might be burnt
Your Power Adapter sounds like it has failed. Replace it, No damage to laptop should occur.
1/19/2010 3:15:54 AM • HP A6795A#0D1... • Answered on Jan 19, 2010
I formatted my nx6310 and now the audio is not working.......
You need to update the chipset drivers as well
8/4/2009 2:26:32 PM • HP A6795A#0D1... • Answered on Aug 04, 2009
2answers
My DV6000 stopped recognising any
Click start, then type cmd into the run box.
When command prompt window opens type
"ping 127.0.0.1"
Now if the ping failed - your adapter is dead-sorry
If it comes back without packets lost - adapter is fine and your neighbors are onto you (just jocking) adapter is fine and there maybe another hundred reasons , but they all have to do with networks.
7/26/2009 10:06:29 PM • HP A6795A#0D1... • Answered on Jul 26, 2009
Replaced hard drive on HP
I would check in device manager (control panel) and see if the network card is listed. It probably has a yellow exclamation point next to it. If there is an exclamation point there, then right click the card and click uninstall. Next, using your wifi to access the internet, download the latest network card driver from the PC vendor website / Motherboard vendor site / discrete network card site.
Install the network card driver and you should be back in business.
7/9/2009 2:02:01 AM • HP A6795A#0D1... • Answered on Jul 09, 2009
Network drivers
You can download drivers from HP's website. They list 77 models in the dv4000 series. Click here for the list, pick your particular model, then choose your operating system. You can then download the drivers you need for your computer.
6/29/2009 6:24:58 PM • HP A6795A#0D1... • Answered on Jun 29, 2009
As i formatted my laptop of model compaq nx6310.. i dont have the software to connect to the network . so pls guide hw is get it done.? thanks in advance
Well i am not sure which operating system you have installed but you can visit this website and it will give you all the drivers you need for your network to work.
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=1839164&lang=en&cc=us&taskId=135&prodTypeId=321957&prodSeriesId=1839143
Hope this helps.
Have a good day.
5/27/2009 8:43:25 PM • HP A6795A#0D1... • Answered on May 27, 2009
Ethernet adaptor driver
this is website you download it its free this is link go for it and its solve you this problem give the
http://driverscollection.com/?file_cid=399774520861f2d23855f7ee899
5/13/2009 11:25:38 AM • HP A6795A#0D1... • Answered on May 13, 2009
I need whole drivers of windows xp
try this......
http://www.drivershq.com/Drivers/Manufacturers.aspx
ps:it dont hurt to be a little more specific.
2/19/2009 4:54:13 AM • HP A6795A#0D1... • Answered on Feb 19, 2009
Network adapter
I need network adapter software for hp presario V6000
1/29/2009 3:00:15 AM • HP A6795A#0D1... • Answered on Jan 29, 2009
I wanna presario v6000 wired
there is a buildin LAN card. the RJ45 plug is located on the left side of the laptop.
12/18/2008 7:28:59 PM • HP A6795A#0D1... • Answered on Dec 18, 2008
Driver for Fibre Channel HBA A5158A
Can you share the firmware version of HBA & server 7400 BIOS version
12/31/2007 6:59:16 AM • HP A6795A#0D1... • Answered on Dec 31, 2007
3answers
I need to know how to turn on a HP X13-04657 LAPTOP, all the lights are on but nothing on the screen.
HP X13-04657, is 2007 PC THOSE this PC has CCFL back lamp strip that is dead.Vista era PC, laptops. are hard to work with now, 17 years old.is this not a HP COMPAQ presario HP X13-04657 (wrong name!) sorry !became HP in 2002. so is HP but manuals are super hard to find now. that x13 is part of the microsoft license code vista. (so is distraction to what it is)the real name of the Laptop is and was Presario CQ61 laptop CQ61 the PC has bottom sticker that shows the real names of PCs.CQ61-219TU is real name of on CQ61, there area many different sub codes, and they are not all the same.CQ61-306AX this had CCFL (cold cathode florecent lamps) that love to fail 3 waysdead, blinks ,dime or yellow = white.was made until 2009 and evolved, to LED backlamps.-410 is CCFLI will answer for CCFL as those just love to fail,but the the test is so easynow the answer for ANY laptop this old. 2007 and older. black screen all the time, and BIOS screens dead, answers only me. here. remove the main battery (large) it simply snaps off the bottom.the power pack is next we run the PC on your power pack AC to DC it must make the screen glow with something, do not use the wrong pack as in mixed up with others.now the lap top seems on, even the fan blows, LED glowpoint a flash lamp at the screen ,dark' room , and of you see any kind of LCD data on the screenthe CCFL lamp below #1 is bad.this is phase 1 testing, as other things can fail too. The keyword below is Mercurythis tells me it is those pesky CCFL glow tubes. 2007 is the year some PC went to LED back lamps. yes I was correct the service manual I did find proves they made both lamp types ccfl-hp07-psnmcz4s4yabbrmds04n13cd-d-0.jpg
4/17/2024 12:37:57 PM • HP Computers &... • Answered 2 days ago
Dove posso scaricare il driver per HP ScanJet 8270? ente compatibile per windows 10...
Question edited for clarity. Question translated to English. We only speak English on this North American website. https://www.google.com/search?q=hp+scanjet+8270+driver+windows+10
HP Scanjet 8270 Document Flatbed Scanner
Hewlett-Packard https://support.hp.com > ca-en > drivers > hp-scanjet-827... Download the latest drivers, firmware, and software for your HP Scanjet 8270 Document Flatbed Scanner ... drivers free of cost for Windows and Mac ... Windows 10 / ...
Hewlett-Packard https://support.hp.com > ee-en > drivers > hp-scanjet-827... Download the latest drivers, firmware, and software for your HP Scanjet 8270 Document Flatbed Scanner. This is HP's official website to download the correct ...
HP Scanjet 8270 Document Flatbed Scanner drivers - Download
Softonic https://hp-scanjet-8270-document-flatbed-scanner-drivers.en.softonic.com Download the latest and official version of drivers for HP Scanjet 8270 Document Flatbed Scanner. This driver package is available for 32 and 64 bit PCs. It is ...
HP Scanjet 8270 Document Flatbed Scanner drivers - Free ...
Download.it https://hp-scanjet-8270-document-flatbed-scanner-drivers.en.download.it Download HP Scanjet 8270 Document Flatbed Scanner drivers varies-with-device. Software drivers for the 8270 flatbed model of the HP Scanjet printer. ..
4/10/2024 8:38:39 PM • HP Computers &... • Answered on Apr 10, 2024
2answers
HP 8440P Laptop. I don't remember my password. Help needed for HP 8440p.
This video shows you what to do if you forget your computer password:
4/6/2024 8:00:24 AM • HP Computers &... • Answered on Apr 06, 2024
2answers
How to do a bios recovery on a hp pavilion dv5-1004nr
This video shows you how to restore the BIOS in your computer:
4/6/2024 7:57:59 AM • HP Computers &... • Answered on Apr 06, 2024
HP A6795A#0D1 Network Adapter Logo
Popular Tags
19 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • HP Computers & Internet
Most Popular Question
dv6000 stopped recognising any
  • Computers & Internet
