20 Most Recent
HP CPQ175KB Keyboard Questions & Answers
Certain keys don't respond when
Replace the keyboard. Something is wrong with the encoder chip inside, and new keyboards are so inexpensive there is no point trying to repair one when it goes bad.
SHIFT + 2 WILL
This is the regional settings for you're keyboard that have changed.
Go to control panel > Regional and Language options (in classic view). In the window that just popped up click on the languages tab at the top and click Details.
When that opens you can choose the US keyboard layout and all will be restored.
I canr find the function
if it not manufactured with the function button i think you can't use another kays as a function keys
best regards
How to key @ on
Press the shift button while pressing the number 2 on the top row.
What key on the hp
The one marked enter of course...and the return key, usually marked with an arrow that goes down and then to the left.
Like this:
The ''h'', ''backspace'' and ''g''
there is no easy fix to this if you haven't spilled anything it most likely means there has been some wear to the conductors meaning you will need to have it repaired
Child was banging keys and all keyboard lights
Unplug the keyboard and switch on the computer. If the computer boots up OK then there may be a stuck button on the keyboard. press each button to see if any feel different to normal. You may be able to repair it by taking it apart, otherwise replace the keyboard.
Effect of sleep button
Hi a_hedges,
Sleep is a power-saving state that allows a computer to quickly resume full-power operation (typically within several seconds) when you want to start working again. Putting your computer into the sleep state is like pausing a DVD player-the computer immediately stops what it's doing and is ready to start again when you want to resume working.
When a computer is in Sleep mode, the power light is blinking and you get a blank screen like it's turned OFF.
On most computers, you can resume working by pressing your computer's power button. However, not all computers are the same. You might be able to wake your computer by pressing any key on the keyboard, clicking a mouse button, or opening the lid on a laptop. Check the documentation that came with your computer or go to the manufacturer's website.
Hope this helps.
Have an HP keyboard-how do
Hi, First press the button print screen from the keyboard and then open paint.
Click on Start ---> then Programs and All Programs ---> then Accessories and then Paint.
Now just paste (Ctrl+V) and now you can save as JPEG, GIF or BMP etc.
You can cut it where you want and you can use it as picture for tutorial etc.
Good Luck
I would like to no
Set your operating system to use a keyboard layout that has the Euro key on shift-5.See
http://en.wikipedia.org/wiki/Keyboard_layout for the keyboard layouts. One option is that you can use US-international layout and use Alt-Gr (Right alt) + 5 to get the Euro. Otehrwise, you need to pick a specific European Keyboard layout that suits your need.
Re HP wireless Elite keyboard
Here's the Microsoft way - note that all Win7 keyboard shortcuts begin with CTRL-ALT-(your shortcut key here).
Note also that a desktop shortcut must already exist to which to be invoked by the keyboard shortcut.....
http://windows.microsoft.com/en-us/windows-vista/Create-keyboard-shortcuts-to-open-programs
The way the Internet community does it:
www.autohotkey.com - freeware - allows you to "package" a number of
keystrokes into a "keyboard macro" and invoke that macro thru
the use of a "hotkey." Keyboard macros can be as short as one
function key, but some Win7 function keys cannot be ove-written, such as F5
What is star tbutton
Ah - the START button is not on the keyboard - its on the Microsoft Windows Taskbar, which is the
line at the bottom of the screen you're reading now. The START button is at the lower left-hand
side of your screen - it has a little "Windows" 4-color flag on it, and says "start".
The way to operate the START button is to move your pointer until the pointer is on the START button,
and then "left-click" on it, which is to say you simply press the mouse button on the left side of the
mouse.
In other words, the Windows start button is virtual (screen-based), and not physical (on the keyboard).
All Windows "buttons" and "tabs" are found on the screen - with one exception - the "Windows" key,
(found next to the ALT key on your keyboard) - its physical. But you'll hardly ever use it.
