20 Most Recent
Amana Clean n Clear Water Filter 12527304, WF30, WF40 Questions & Answers
Need to find water filter on my amana model
Install Water Filtration Cartridge (some
models)
a. Remove bypass cartridge from water filter head in rear
right corner of refrigerator section. Twist cartridge
counterclockwise 1/4 turn and pull down to remove.
Save bypass for use at a later date.
b. See Water Filtration System Installation and
Operating Instructions provided with water filter
cartridge for filter installation and operation.
6/20/2023 3:26:22 PM •
Amana...
Answered
on Jun 20, 2023
Afd2535des not cooling in any department, when I opened the doors, the lights work and the led temp control lights up. I hear a fan start and 5 seconds later the fan stops n leds shut off.
- Check the thermostat: Make sure the thermostat is set to a temperature that is low enough to cool the refrigerator. If the thermostat is not working properly, it may need to be replaced.
- Check the condenser coils: The condenser coils on the back of the refrigerator should be clean and free of dust and debris. If the coils are dirty, the refrigerator will not be able to cool properly. Use a vacuum cleaner or a brush to clean the coils.
- Check the fan motor: If the fan motor is not running, the refrigerator will not be able to cool properly. Check if the fan motor is receiving power and if it's spinning freely. If the fan motor is faulty, it will need to be replaced.
- Check the start relay: The start relay helps the compressor start up. If the start relay is faulty, the compressor may not start and the refrigerator will not be able to cool properly. If the start relay is faulty, it will need to be replaced.
- Check the compressor: If the compressor is not working, the refrigerator will not be able to cool properly. Check if the compressor is receiving power and if it's running. If the compressor is faulty, it will need to be replaced.
2/16/2023 2:42:10 AM •
Amana...
Answered
on Feb 16, 2023
No power to Amana ice and water dispenser. Rest of refer runs fine.
It's possible that the issue could be with a micro switch located on the ice maker cabinet that is activated when the prong on the back of the ice/auger tray is inserted. It's also possible that there could be another issue with the dispenser, such as a problem with the wiring or a malfunctioning component. I would recommend checking the wiring and testing any other micro switches or components that are related to the dispenser to see if they are functioning properly. If you are unsure how to do this, I would recommend consulting the user manual or contacting a qualified technician for further assistance.
1/14/2023 10:27:43 AM •
Amana...
Answered
on Jan 14, 2023
My Amana 19cu ft refrigerator, freezer on the bottom. Refrigerator stopped working, freezer is still working, MODEL DRB1901CW. S/N109533070CE
There are plenty of reasons this could happen like the following:
PROBLEM
POSSIBLE CAUSE
Loud operating sound level
• See "Sound Information" section for explanation of normal operating sounds
Freezer too warm. Compressor not operating
• Freezer temperature set too warm
• Defective compressor
• Defective overload or relay
Refrigerator too cold
• Refrigerator temperature set too cold
• Chefs Pantry control set too cold or misaligned allowing freezer air to escape into refrigerator section
• Freezer temperature set too cold
• Restricted condenser air
• Refrigerant shortage or restriction
• Refrigerant overcharge
Freezer too warm. Compressor cuts off on overload
• Heavy usage
• High ambient
• Defective condenser fan motor
• Loose or missing condenser fan blade
• Improper voltage
• Defective relay or overload
• Compressor motor winding
• Non-condensibles in system
Freezer too warm. Compressor operating
• Opened door
• Heavy usage
• Defective freezer fan motor
• Opened defrost thermostat
• Opened defrost heater
• Loose or missing freezer or condenser fan blade
• Heavily frosted evaporator
• Inefficient compressor
Refrigerator too warm
• Refrigerator temperature set too warm
• Return air or air supply duct blocked
• Chefs Pantry control set too warm or air supply tube blocked
• Heavy usage
• High ambient
Problem
Possible Cause
Freezer too cold
Long off cyde
• Low ambient
Short off cycle
• Heavy usage
• High ambient
• Light constantly on
• Poor door gasket seal
Long or continuous run cyde
• Heavy usage
• High ambient
• Inadequate condenser air flow
• Loss or restricted refrigerant
Short run cycle
• Light usage
• Low ambient
Exterior cabinet condensation
• High humidity. Design accepts beads of water on cabinet exterior after 4 hours with 0° to 2°F (-18° to -17°C) freezer food temperature and 38° to 40°F (3° to 4°C) refrigerator food temperature in 84% R.H. conditions. See "Typical Sweat Pattern" section under above conditions.
• Insulation void
2/24/2021 9:30:34 AM •
Amana...
Answered
on Feb 24, 2021
