20 Most Recent
HP OfficeJet 6600 e-All-In-One Inkjet Printer Questions & Answers
Hp officejet 6600 error code 0x610000f6 beware spam number 1*800*532*4187
HP has done something extraordinary with their product. But a device that's working flat out to print thousands of pages a year can still be uncertain from time to time. And
Hp Printer Error 0x610000f6 is one of the most common that HP printer users face. Usually, the error note you were shown can be due to the paper jam. Or the reason can be hardware failure with both the printer or the print head.
Right steps to Resolve HP Printer Error 0x610000f6-
1. Switch off the printer and cut the power cable.
2. Presently, open the cover of the printer and check for any orange tape or white polystyrene and untag it if necessary.
3. Next, make sure there are no additional objects such as paper clip and others are present inside the printer.
4. Lastly, close the cover and reconnect the printer. Then turn it on.
If the problem remains, check this blog or call Printer Error support services to stop more printer damage the number is in this blog that is previously mentioned.
Printer dosent print after I got refills
Chances are this is because you either bought recycled, refilled cartridges, or aftermarket new ones. The printer manufacturers sell their printers at less than cost in order to make their money back on ink sales. OEM ink is expensive, but the easiest to use since the smart chips installed on them work with the printer firmware to verify that original, new cartridges have been installed. That said, there are aftermarket manufacturers that now sell ink cartridges with smart chips installed as well. You may also find that some manufacturers provide a workaround for refilled, reused cartridges. You can Google this on the Internet. Despite what some will say, you will not void your warranty by using an aftermarket cartridge, but you most likely will not get the same quality as an original.
How remove feeder tray from 6600
Hi Ed Walsh,
When you say feeder tray, are you speaking of the document feeder tray, or the paper input tray? The document feeder tray is not customer replaceable so it will not be removable. The input paper tray is however removable. Perhaps you will find the support page for your Officejet 6600 helpful:
HP Officejet 6600 All in One Printer H711a H711g How to
I hope this helps.
I work on behalf of HP.
Will not scan to computer
This is not a simple answer.
You have to check the hardware connection, and also the software settings whether it has been changed.
1) For hardware connection, you have to check the network cabling whether they are really connected by applying certain testing, in which your IT staff should handle that;
2) for software settings, you IT staff need to check whether the scanner driver is installed properly, whether the IP address of the scanner/printer has changed from previously set. All these stuff need certain networking knowledge. Also the firewall setting is an issue that can prevent communication to the printer from the computer.
My printer will print from Word but not from
Open an Internet Explorer window, and go to File>Print. You should see your printer listed. If you use more than one printer, select the one you want to use. If no printer is showing, go to the left of the window until you can see Add Printer, and tell it what printer to use.
