20 Most Recent
IBM Ww1000rf Wheelwriter Refurbished Typewriter Questions & Answers
Machine wont power on, cord and power going to it are good.
Could be a bad power supply or bad function board. EBM has both parts available 800-832-6522. You would have to remove plastic cover over the function board and check for voltage on the wires from the power supply (where the on/off switch is to the function board. If no dc voltage is present at function board, then power supply has failed. Power supplies are wearing out due to age.
How to make multiple copies on IBM Wheelwriter 2
Two things. Multipart forms have a film on the top copy. Change the ribbon to another brand. Some work better than other. Probably if it printing some on the top copy, and it works on regular paper.
If it does work on regular paper its the ribbon may be old or change to different brand.
A work around is to use eraser on the form where you going to print. This will the remove the film, and allow to type there.
