20 Most Recent Canon CB-2LX Battery Charger Questions & Answers
Most of the charger will support 110v / 220v automatically. Look at the label on the back of the charger to verify that.
Canon CB-2LX... | Answered on Nov 09, 2013
Hi. Have you check the lower cover ( right side of the machine ) . If all covers are closed maybe is a sensor problem
Canon Office... | Answered 14 hours ago
Please check internal print first if not ok than check developer Assembly First, magnet roller surface is balance i mean doctor blade is working properly toner layer is balance if not clean the developer cylinder and if layer is balance check the LD unit
Canon Office... | Answered Yesterday
That printer is not compatible with that version of windows, try using windows Vista driver
Canon Office... | Answered 3 days ago
Please check this path in service mode:
COPIER/OPTION/BODY item: Po-cont : is this item is zero change it to 1. Or vice-versa, restart your machine and make some prunts
  • Code: E000-0000
  • Description:The reading of the main thermistor does not reach 30C 1 sec after the main power switch is turned on. Or, it does not reach 70C 2 sec thereafter
  • Causes:The fixing film unit is faulty. The main thermistor has an open circuit. The fixing heater has an open circuit. The main power supply PCB is faulty. The DC controller PCB is faulty. To reset the error, execute the following in service mode: COPIER>FUNCTION>CLEAR>ERR.
  • Remedy:1. Connector Is the connector of the fixing assembly connected? a. main power supply PCB (J8) <-> relay connector <-> heater b. DC controller PCB (J320) <-> relay connector <-> thermistor NO: Connect the connector. 2. Fixing film unit (thermistor) Check the interval between pin 1 and pin 2 and between pin 3 and pin 4 of the connectosr (4-pin) of the thermistor for electrical continuity. Is it W (open)? YES: The heater has an open circuit, or the thermal switch is open. Replace the fixing film unit. 4. Main power supply PCB, DC controller PCB Press the Start key. Is the drive voltage of the heater supplied by the connector J8 of the main power supply PCB? Main heater: between J8-1 (FSR1) and J8-5 (FSR COM) Sub heater: between J8-3 (FSR2) and J8-5 (FSR COM) YES: The heater drive power supply is faulty. Replace the main power supply PCB. NO: The thermistor control mechanism is faulty. Replace the DC controller PCB.
  • Code: E001-0000
  • Description:The main thermistor detects 250C or higher
  • Causes:The fixing film unit is faulty (i.e., the thermistor has a short circuit). The main power supply PCB is faulty. The DC controller PCB is faulty. Caution To clear the error, execute the following in service move: COPIER>FUNCTION>CLEAR>ERR.
  • Remedy:Check the interval between pin 1 and pin 2 and between pin 3 and pin 4 of the connectors (4-pin) of the thermistor for electrical continuity. Is it 0 W (short circuit)? YES: The thermistor has a short circuit. Replace the fixing film unit. If the thermistor has a short circuit, the indication in service mode (COPIER>DISPLAY>ANALOG) will be as follows from the start: FIXC= 250°C for the main thermistor; FIX-E=310°C for the sub thermistor. 2. Main power supply PCB, DC controller PCB Try replacing the main power supply PCB. Is the problem corrected? YES: End. NO: Replace the DC controller PCB.
Description:The thermistor has an open circuit or a short circuit.
The heater has an open circuit.
The thermal fuse has blown.
The High-voltage power supply board has a fault.
The DCNT board has a fault.
Canon CB-2LX Battery Charger Logo
4 questions posted
Clive
Clive
old marine
old marine
View Most Popular
  • Canon Office Equipment & Supplies
Most Popular Question
need transformer use canon battery
  • Office Equipment & Supplies
