20 Most Recent Crosley CR49 Portable Traveler 3-Speed Turntable Record Player Spare Questions & Answers
Crosley turn table is not spinning. Tried replacing belt and moving cue lever to right then left. Think it might be the arm or cue lever. Does anyone have an idea what the problem is or a solution?
Since it is new, you should probably return for refund or exchange. My guess would be it is the micro switch controlled by the arm. Make sure the power is turned on and the unit's function selection is set on PHONO and then gently move the tone arm to the right until you hear a "click". Remove any cassettes that might be in the cassette player. Lift the tone arm and carry it over to the beginning of the record. TroubleShooting
1/27/2016 3:59:36 PM • Crosley CR49... • Answered on Jan 27, 2016
Crosley stove door isn't locked but when I push bake says unlock door
You can try this..turn the circut breaker off for a couple of minutes to see if it resets.
12/23/2022 5:27:20 PM • Crosley Kitchen... • Answered on Dec 23, 2022
Why doesn't it turn on when I hit the brake?
I think you need you to find a technician for that fix.https://chicagotuckpointingandmasonry.com
3/22/2021 2:44:59 PM • Crosley Kitchen... • Answered on Mar 22, 2021
I have a Crosley gas oven model CG31200BDW the stove turns on and is working fine, however the oven will not heat up. Please help?
This model number does not show valid, please double check. In general, if the surface burners work, then suspect a bad oven ignitor. Does the ignitor glow? If so, and the burner doesn't come on within 30 seconds, replace the ignitor, it's weak and not passing enough power to open the gas valve. If the ignitor does not glow then you must check the ignitor for continuity (replace if open/no circuit) and back check the circuit for lost power. If not the ignitor then suspect a bad relay on the control board.
11/8/2020 2:21:16 PM • Crosley Kitchen... • Answered on Nov 08, 2020
F5 code on crosley model ce3878vvv stove oven wont work or broiler
Most Frequent Causes for F5 - A "watchdog" circuit on the clock assembly control board is sensing a hardware problem
11/10/2018 5:52:29 AM • Crosley Kitchen... • Answered on Nov 10, 2018
Get a f-5 code on my crosley m#ce3878vvv stove when I try to use oven turn breaker off and on still does same code broiler does same code burners work fine
Replace clock assembly
https://www.repairclinic.com/RepairHelp/FaultCodes/10/Range-Stove-Oven
11/1/2018 5:52:31 PM • Crosley Kitchen... • Answered on Nov 01, 2018
I have a Crosley oven and I'm getting a beeping sounds and error message F31 and I cannot find my manual How can I fix it?
I had the same thing going on literally just now. I unplugged it, plugged it back in, and now it is working fine. O.o
10/7/2018 6:05:13 PM • Crosley Kitchen... • Answered on Oct 07, 2018
C31000PAW Crosley propane range. Oven pilot burns and pilot flame gets bigger when the thermostat is turned up but the burner never fires up.
Check the burner orifice and clean them, boil over and food can plug them
1/5/2017 3:43:43 AM • Crosley Kitchen... • Answered on Jan 05, 2017
Crosley CR49 Portable Traveler 3-Speed Turntable Record Player Spare Logo
1 questions posted
Top Crosley Kitchen Ranges Experts
vince
ADMIN Andrew
ADMIN Andrew
Are you a Crosley Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Crosley Kitchen Ranges
Most Popular Question
crosley turn table not spinning tried
  • Kitchen Ranges
