It's important to be cautious when rewiring a relay, as incorrect wiring can cause damage to the water cooler or even create a safety hazard. If you're not familiar with electrical wiring, it's best to consult a professional to do the job.
Assuming you have the replacement relay and know which wires connect to it, here's a general guide to rewiring a relay:
Turn off the power to the water cooler. This is essential for your safety.
Locate the relay and remove the wires from the old relay. Note the color and position of each wire so you can connect them to the new relay correctly.
Connect the wires to the new relay in the same positions as they were in the old relay. The most common connections are:
The black or brown wire should connect to the "L" terminal of the relay.
The white or grey wire should connect to the "N" terminal of the relay.
The red or blue wire should connect to the "C" or "NC" terminal, depending on the relay type.
Double-check that all connections are tight and secure. Loose connections can cause problems, such as arcing or overheating.
Turn the power back on and test the water cooler to ensure it's functioning correctly.
Again, if you're unsure about rewiring a relay, it's best to seek professional help.
Either the draining gasket or the cooling tank or the push in filterings could be not working and should have to be replaced in the water drinking fountain.looking for where the leak is coming from for the water drinking fountain then and get the parts or the part that is having water leaking from replaced.
Ain't no fuse. I would first check the thermostat for continuity. If you don't have a meter simply bypass the thermostat for a few minutes to see if the fountains cools but DO NOT LEAVE IT LIKE THAT. Water fountains recover cold water quickly, if left like that the tank would freeze and bust so don't bypass the stat and go shopping. If that turns out to be fine then check the compressor relay. The relays do a lot of work if that fountain is anywhere near a school or an office. The condenser gets an awful lot of dust in it especially if the unit is outdoors. Down south where I live we do put some water fountains outside. Give it a good cleaning. Replace the open component and you should be good to go. A compressor failure or gas leak is RARE on water fountains. I suspect your compressor relay is shot: If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Many times a freezer and/or refrigerator
do not work right because of a dirty condenser coil...there are also many other
things that can go wrong. If you are hearing a clicking or buzzing then check out the
last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start
trouble shooting your unit...and something that you can do rather then calling
a repair person to do a simple thing for you...
Humming is a classic sign that the start / run capacitor for the compressor has failed. Call for service, have it checked for gas and condenser cleaned.
Question edited for clarity.
Question moved from Cars and Trucks category.
This is primarily a South African make and not one we know here in North America. This link should work better where you live and provide some insight.
https://www.google.com/search?q=DEFY+DOUBLE+DOOR+FRIDGE+DFF417+error+OC2
On an AEG SANTO 3533, the tray sits on top of the compressor. There is a short metal "tunnel" on top of the compressor. The tray has a plastic clip in the middle which goes through the tunnel and latches up on the other side. To remove, reach to the back of the metal in the middle of the tray, press the plastic clip firmly down, and pull/wiggle the tray backwards horizontally to remove. Needed a torch to see clearly on mine. One of these things that's easy once you've done it once.
Copper has anantibacterial effect. Studies recommend storing water in copper containers for several hours before consumption to maximize this benefit. Some research suggests 48 hours. perhaps explore dedicatedcopper water bottlesfrom reputable sources for optimal water storage.
This refers to water, not juices.
Sometimes the timer jmalfunctions and the refrigerator will not go in to a defrost mode. Try unplugging it and defrost the refrig and plug it in again.
