20 Most Recent
Ridgid Pressure Washer. 3000 psi 2.6 GPM Gas Pressure Washer with CAT Questions & Answers
I have a power problem
I leave my 18 volt batteries charging year round even if I do not use my drill I switch batteries about once a month to keep them both up to snuff. your new chargers are made to do that unless the instructions tell you not to. I was told even new batteries will not hold their charge if allowed to completely run down and stay there.
Low pressure
Bypass valve on pump is stuck. Not sure you can fix it but you can try to take the output side of the valve apart on the pump to clean it up or spray some silicone spray inside the output side of the pump. If this doesn't work you will need a new pump.
Why Does my pressure washer shut down?
Will need more info for an educated answer. does it occur after 5 minutes? does it have gas? does it shut down when you stop spraying for a minute? If so, it could be the pressure relief valve in the unit. I think more information would be helpful to assist you properly. Include make and model too.
