20 Most Recent
Stanley 2350 PSI 5 HP 2.3 GPM Gas Pressure Washer - Non CA Questions & Answers
Stanley 10-801 utility knife. How
On the pivot end of the bladed knife is a black plug that says pull. They actually mean "Push". push it away from the knife body and rotate the handle half it's mounted in, down. The body will rotate in half , revealing the utility blade and more blades in the rear storage.Also note the blade depth adjustment has a locking detent. You have to push it to the right to unlock the utility blade.and push it to the right when retracting to fully retract and lock the utility blade.
Stanley P1800S pressure washer lost pressure after a few uses
The valve-o-rings + [ parbaks seals ] where the pressure can be adjusted with.
Control the water inlet filter or hose that there are no waterlock couplers are used or is mounted
on the wrong site on the hose , that it is used as water inlet on the tap.
How do I get the top off? STUCK!
Hi Chris:
It is usually easiest to rest the weight on the tailgate of a pickup truck (or some other device) and then slip out of the harness.
Another technique is to lift bend forward while at the same time rising one shoulder and lowering the other. That will create "slack" on the low shoulder side allowing you to get that arm out.
Cheers
