20 Most Recent
Zodiac Lm3-24 Salt Water Chlorinator W385210 25k Gallon Questions & Answers
Zodiac lm3
The lm series chlorine generator has a tri-sensor inside the cell that measures flow, water temp, and salt level in pool. If the controller is indicating no flow after it has been cleaned properly, then the cell is most likely in need of replacement.
Where does the flow gauge go on the zodiac barracuda g3
the flow gauge goes on the end of the vacuum hose where you would normally plug the cleaner into.
The gauge is only used in the initial setup stage to set the correct flow rate and then the gauge is taken off and the cleaner put on
