20 Most Recent Craftsman 1700 PSI, 1.3 GPM Electric Pressure Washer w/ Steam Cleaner Questions & Answers
0answers
Craftsman 1700 leak
craftsman 1700 pressure washer 1700 elect. with steamit sucks down the soap down when I wash my golf cart. I do it fast any way slowing it diwn
6/3/2013 12:48:44 PM • Craftsman 1700... • Answered on Jun 03, 2013
0answers
Manuals
Be the first to answer 5/3/2013 7:00:43 PM • Craftsman 1700... • Posted on May 03, 2013Be the first to answer
Does anyone know the length of a craftsman part number 66054 link arm.
The Craftsman part number 66054 corresponds to a link arm, but without specific details or access to Craftsman's database, it's challenging to provide the exact length of this part. To find the precise length of the link arm with part number 66054, I recommend checking the product description or reaching out to Craftsman directly through their customer support or website. They should be able to provide you with the accurate information you need.
4/3/2024 12:56:29 PM • Craftsman Garden • Answered on Apr 03, 2024
Craftsman Riding Lawn Mower 17.5hp. Why Engine Turns Slow, Starter Hanging Up, Won't Turn Over?
Hi Joe Still having trouble with that old mower! I thought you fixed it? You stated the reason it was turning over and lock up the mower had the wrong starter on it the Starter Motor Drive Bendix had 16 teeth and the mower needed a Starter with 14 teeth so I changed the Starter out. That's what I did. I reckon you are using batteries that are wearing out and don't have the required amps. Jump start the mower using your Santa Fe with the engine running. Or take the batteries to an Interstate Battery shop and ask them to test them. That is free, but they can also pulse charge them to desulphate the plates. There is a small charge for that and they keep the battery for 24 hours. Other things you can try. Remove the starter and connect it direct to the battery. See if it spins freely? Turn the engine over by hand to see if there is stiffness. Then do it with the plugs out. ..
3/11/2024 10:23:57 PM • Craftsman Garden • Answered on Mar 11, 2024
Craftsman weed eater, gas 25cc. How to replace the string line on it please?
Operator's Manual - CRAFTSMAN
Sears https://i.sears.com > mp-tc > prod_1977954512 PDF WEEDWACKER GAS TRIMMER. R. Model No. 316.711192 ... 25 cc (1.52 cu. in.) 0.025 in. (0.635 mm) ... Always use the fresh fuel mix explained in your operator's manual.
Sears https://i.sears.com > mp-tc > prod_1977959112 PDF Operator's Manual. CRAFTSMAN. 2-Cycle. WEEDWACKER GAS TRIMMER. Model No. 316.711471. INCREDI-PULLMW/TH. UNBELIEVABLE STARTING EASEâ„¢. CAUTION: Before using this ...
Instruction Manual
Sears PartsDirect https://c.searspartsdirect.com > doc PDF Jan 10, 2005 - For one year from the date of purchase, when this Craftsman DGas Powered. Weedwacker. Line Trimmer is maintained, lubricated, and tuned up ...
User manual Craftsman CMXGTAMD25SC (English
Manua.ls https://www.manua.ls > not categorized > Craftsman Manual. View the manual for the Craftsman CMXGTAMD25SC here, for free. This manual comes under the category not categorized and has been rated by 3 people ...
Operator's Manual
Sears PartsDirect https://c.searspartsdirect.com > doc PDF Operator's Manual. M. 4-Cycle. WEEDWACKER® GAS TRIMMER. Model No. 316.794490. CAUTION: Before using this product, read this manual and follow all its Safety.
Craftsman WEEDWACKER 358.791520 Instruction Manual
ManualsLib https://www.manualslib.com > manual > Craftsman-We... View and Download Craftsman WEEDWACKER 358.791520 instruction manual online. 25cc/1.5 cu.in. 2-Cycle 17 Inch Cutting Path / 0.080 In. Line GASOLINE ...
Craftsman WEEDWACKER C944.514460 Instruction Manual
ManualsLib https://www.manualslib.com > manual > Craftsman-We... View and Download Craftsman WEEDWACKER C944.514460 instruction manual online. 25cc / 1.5 cu.in. 2-Cycle 17 Inch Cutting Path / 0.080 In. Line GASOLINE ...
3/10/2024 4:11:39 PM • Craftsman Garden • Answered on Mar 10, 2024
Craftsman GT3000 garden tractor lawn mower. Why is my clutch not engaging on my tractor?
Check to see if the drive belt has snapped or come off the pulleys? https://www.google.com/search?q=craftsman+gt3000+drive+belt ..
3/10/2024 4:07:41 PM • Craftsman Garden • Answered on Mar 10, 2024
Why does the engine turn over and stop like the battery or starter is bad? How do I adjust the valves on a Craftsman riding mower 17.5 HP engine?
Hello Joe How old is the battery? Battery life in mowers is bad because they usually aren't well looked after in the winter, 6 months use and 6 months neglect. Also fuel is often left in the tank and in the carb which goes funky. Do you have a compression tester? Valve adjustment https://www.google.com/search?q=craftsman+riding+mower+17.5+adjust+valve+clearance ..
3/1/2024 2:07:15 AM • Craftsman Garden • Answered on Mar 01, 2024
How do I get to the ender real of my Weedwhacker when I can't even get the bolt to come off?
here is link to manual copy and paste https://www.searspartsdirect.com/manual/4v0ctntnsv-000247/craftsman-316711370-gas-line-trimmer-parts
2/19/2024 9:52:31 PM • Craftsman Garden • Answered on Feb 19, 2024
I have a craftsman ws 2400 2-cycle 27cc weed eater and the pull rope to start it broke . How do I fix it?
Video links at the bottom of this feedback. Turn Off the Ignition: Move the ignition switch on the Craftsman trimmer into the "Off" position. Remove the Starter Assembly Cover: Use a screwdriver to unscrew the starter assembly cover and remove it from the trimmer. Prepare the New Pull Cord: Cut off the old cord from both the pulley and the starter handle. Dispose of the old cord. Replace the Pull Cord: Flip the starter cover over and replace the pull cord. Make sure it's securely attached to the pulley. Reassemble the Starter Assembly: Put the starter assembly cover back in place and secure it with the screws. How to Replace the Pull Cord on a Craftsman Weed Trimmer (youtube.com) WS 2400 (CMXGTAMDSS27) (41ADSS27793) - Craftsman String Trimmer Parts Lookup with Diagrams ' PartsTree
2/15/2024 9:32:42 PM • Craftsman Garden • Answered on Feb 15, 2024
Repairing a craftsman ws 2400 2-cycle weed eater 27cc pull rope
This u tube video may help you https://www.youtube.com/watch?v=G9NM2V27WvY
2/15/2024 7:21:15 PM • Craftsman Garden • Answered on Feb 15, 2024
LT 100 craftsman riding lawn mower 17.5hp what all can cause the engine to turn over slow?
Clean the battery posts and the connectors with a wire brush and then smear them with Vaseline. Tighten the connectors well. Take of the negative ground to the chassis and do the same with that. Also take the battery to an Interstate Battery outlet and ask them to load test the battery. Voltage is one thing but Cold Cranking Amps (CCA) is the important part of a battery. They do it for free and it takes 2 minutes, and you get a printout, CCA on the battery to CCA Actual. ..
1/28/2024 1:12:09 AM • Craftsman Garden • Answered on Jan 28, 2024
2answers
Craftsman snow thrower model 247.881731. What size socket do I need to remove the spark plug from my machine please?
13/16 in. or 20mm
Gap 0.025 in.
Part Numbers
MTD 951-10292
MTD 951-10292A
Torch F6RTC
NGK BPR6ES
1/14/2024 12:02:23 AM • Craftsman Garden • Answered on Jan 14, 2024
What size of spark plug does the Craftsman WS2200 25cc weed eater use please?
Question edited for clarity.
WS 2200 (CMXGTAMDSS25) (41ADSS25793) - Craftsman ...
PartsTree https://www.partstree.com > models > ws-2200-cmxgt... Repair parts and diagrams for WS 2200 (CMXGTAMDSS25) (41ADSS25793) - Craftsman String Trimmer. ... 753-06847 - Spark Plug, RDJ7J. 753-06847. Spark Plug, RDJ7J. $ ...
Spark Plug for Craftsman WS2200 String Trimmer - OEM
eBay https://www.ebay.ca > ... > Lawn Mower Parts Spark Plug for Craftsman WS2200 String Trimmer - OEM - NEW - Made in USA ; Condition. New ; Quantity. 1 available ; Item Number. 335039517636 ; Compatible Brand. US$8.95 https://www.google.com/search?q=craftsman+ws2200+spark+plug ..
12/19/2023 5:38:40 AM • Craftsman Garden • Answered on Dec 19, 2023
Trying to find a manufacturing date on a Craftsman
Does it have an EPA date thus narrowing down the time frame
10/27/2023 3:56:41 PM • Craftsman Garden • Answered on Oct 27, 2023
Craftsman 1700 PSI, 1.3 GPM Electric Pressure Washer w/ Steam Cleaner Logo
Popular Tags
8 questions posted
Top Craftsman Garden Experts
john h
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
View Most Popular
Craftsman Garden
  • Craftsman Garden
Most Popular Question
craftsman 1700 leak
  • Garden
