20 Most Recent Sharp R-1875 1.1 cu ft over-the-range microwave 850w Questions & Answers
The fan on my Sharp R930AK won't stop after broiling.
Due to the temperature or a failing sensor?
7/23/2015 1:30:47 AM • Sharp Kitchen... • Answered on Jul 23, 2015
Sharp double grill oven
see instruction Sharp 25JTF manual
4/7/2015 12:42:48 AM • Sharp Kitchen... • Answered on Apr 07, 2015
0answers
Sharp r-1512 repair manual How do
At our Web site, we have a video available showing how to remove the grille and control panel assembly in under 5 minutes.
We have the service / repair manuals for this model and have uploaded it to our site here and here for free download to help you.
9/24/2011 4:14:36 PM • Sharp Kitchen... • Answered on Sep 24, 2011
I donot have a
First of all, here is the main ONLINE SUPPORT page for your model (search for model R874):
http://www.sharpelectronics.info/Manuals.aspx
And here is a direct link to the ONLINE USER'S MANUAL for that model:
http://www.tradenet.sharp.co.uk/files/Consumer_Electronics/Microwave_Oven/R874/R874589.pdf
To view the Support Page or the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated or the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents. You can download this free at WWW.ADOBE.COM if necessary. Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, and then just follow the onscreen instructions to install it.
Please comment back here to this page if you have any questions, have difficulty accessing the links, or just require further general assistance and I will respond as soon as I see it.
Thank you very much and good luck.
4/16/2011 3:31:35 PM • Sharp Kitchen... • Answered on Apr 16, 2011
I turn on my sharp
ewan
12/15/2010 8:16:34 AM • Sharp Kitchen... • Answered on Dec 15, 2010
2answers
I pushed start, it started
There is a fuse inside the microwave that blew.
To change the fuse you will have to remove the cover of the microwave, find the fuse, usually right where the power cord enters, and replace the fuse...
It could have blown from age a low voltage situation, or a bad component... I would try to run it before replacing the cover...but make sure not to run it empty.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....Microwave Oven Basic Troubleshooting Tipsheatman101
11/19/2010 2:02:00 AM • Sharp Kitchen... • Answered on Nov 19, 2010
0answers
Sharp KB-3401LW 30 Insight Electric
Either your clock has slipped inside and you can easily re mount it,or replace the clock.
6/4/2008 8:58:50 AM • Sharp Kitchen... • Answered on Jun 04, 2008
Whirlpool Range Model WBP 34500. I need a wiring diagram for it please?
Unfortunately not for that model. I realize this is an old question but it is stuck and needs answering to get rid of it. :>D https://www.google.com/search?q=Whirlpool+Range+WBP+34500+wiring+diagram ..
4/9/2024 5:46:28 AM • Kitchen Ranges • Answered on Apr 09, 2024
Sirius SU1 Wall Mount Chimney Range Hood, 600 CFM. Not working at all. Replaced board?
It sounds like your new board is faulty or there are bad connections to and from it. Have you asked Sirius Helpdesk Support? https://www.google.com/search?q=Sirius+SU1+no+power ..
3/25/2024 11:28:36 PM • Kitchen Ranges • Answered on Mar 25, 2024
I am looking for a thermostat for my Samet gas stove. Having difficulty to find the part. Any replacements that might also work?
send me a picture of the thermostat body and i may be able to help. 35 years + restaurant equipment repairs. Theseafox Enterprises
3/23/2024 12:56:00 AM • Kitchen Ranges • Answered on Mar 23, 2024
How old is Whirlpool Gas Range Model #10116557A
Conflicting information in the link. My best guess is 2010 Month 11.The only way to be sure is to phone them.EDIT to Add./ I just noticed you typed 'Whirpool', I have edited your post but am not able to edit my link. When it opens, add the 'L' and press Enter.https://www.google.com/search?q=How+old+is+Whirpool+Gas+Range..
3/14/2024 2:02:48 AM • Kitchen Ranges • Answered on Mar 14, 2024
Why is my commercial oven emitting so much Carbon Monoxide?
I am a retired career chef, and had this one oven with choking CO in an airport catering kitchen. We had it serviced and it was fixed. It sounds like yours is not getting enough air mixed with the gas. Adjusting the gas is one thing but the venturi to the burners can partially block and unburned gas spills over. Remove the burner and venturi and boil it out in whatever you boil your fryers out with. Are you on mains gas or propane because the jets are different. https://www.google.com/search?q=commercial+oven+emitting+too+much+Carbon+Monoxide ..
3/1/2024 12:19:25 AM • Kitchen Ranges • Answered on Mar 01, 2024
Oven temperature not what it should be. Set at 350 and my oven thermometer only went up to 335.
That seems quite common. Place your temperature sensor, alongside the therocouple of the oven, to check its accuracy.
2/23/2024 9:36:59 PM • Kitchen Ranges • Answered on Feb 23, 2024
Where can I find a maintenance manual for a Teba TFB21Y gas cooking stove
There isn't one for the reason I stated before. Call for service. https://www.google.com/search?q=Teba+TFB21Y+service+manual The only thing available is Parts, but that is for service engineers.
Teba TFB21Y (TFB21F20) oven spare parts - FixPart
fixpart.ie https://fixpart.ie > oven-spare-parts > tfb21y-tfb21f20 Teba TFB21Y (TFB21F20) oven spare parts needed? ? 16+ spare parts deliverable. ? Next day delivery* ? Customers give us a 9.0. ..
2/23/2024 4:04:39 AM • Kitchen Ranges • Answered on Feb 23, 2024
Sharp R-1875 1.1 cu ft over-the-range microwave 850w Logo
3 questions posted
Top Sharp Kitchen Ranges Experts
Paul Carew
john h
ADMIN Andrew
ADMIN Andrew
Are you a Sharp Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Sharp Kitchen Ranges
Most Popular Question
tell alarm set am or pm
  • Kitchen Ranges
