20 Most Recent Sears 25 cc Gas Blower Questions & Answers
Hello, I have a sears leaf blower 358.794762 that will not start. It's almost like the primer bypasses the carb
Craftsman Leaf Blower Model 358.794762 (358794762) Parts
www.repairclinic.com/.../Model-358794762-Craftsman-Leaf-Blower-Par... This part fits your Leaf Blower. Husqvarna fuel filter. If the fuel filter is clogged, it willrestrict the flow of fuel to the carburetor. As a result, the engine may not start.
Hello, I have a sears leaf blower 358.794762 that will not ...
11/26/2015 1:52:47 AM • Sears 25 cc Gas... • Answered on Nov 26, 2015
Have Sears 358.794741 Gas Blower that quit and
ARE u certain fuel is reaching piston? do a 1/2 sirenge-force' fuel thru carb into the cylinder and try to start if nothing' check compression using a any conventional engine comp gage if compression is 95 or lower entire unit is toast!! most 2-strokes including huska ,echo and stihl will egg-shape cylinder-walls due to wrong mix!!! and happens over two to three hrs use with wrong mix..2 stroke ANTHING MUST be perfect in fresh-fuel with fresh proper oil mis usually 40-1 unlike trimmers most are 32-1 as is chain saws..compression test is always done 1st before i look for da obvious no-spart/fuel da cheapest fix.. for weak or little comp the unit MUST be used for parts and buy an identical unit and use it right!
8/8/2013 5:12:36 PM • Sears 25 cc Gas... • Answered on Aug 08, 2013
Looking for docs on Sears Dual Motion Sander Model 315.116163
The following link has a parts diagram of a model very close to the one you depict. Perhaps examining that will help. https://www.searspartsdirect.com/model/4ohn323hc3-000247/craftsman-315116162-power-sander-parts
9/4/2023 2:16:52 AM • Sears Garden • Answered on Sep 04, 2023
How many cubic feet in a Kenmore 106.76232402.
Top Mount and Bottom Mount are all pretty much the same. There are variations in side by sides. https://www.google.com/search?q=kenmore+106.762+cu+ft ..
10/28/2022 2:22:07 AM • Sears Garden • Answered on Oct 28, 2022
Sears Craftsman LT2000 Lawn Tractor. How do I determine the age of my tractor?
Question edited for 'make model (what it is)'. Question moved from Optics. This is your Date Code in the serial number. 06-24-04 June 24, 2004 1,747th unit made.
5/19/2022 2:17:35 PM • Sears Garden • Answered on May 19, 2022
Manual for a Sears 242 28556
sears web site
7/22/2021 11:04:46 PM • Sears Garden • Answered on Jul 22, 2021
Sears tractor riding lawnmower. Check battery
Lots of information here https://www.google.com/search?q=Sears+tractor+riding+lawnmower.+Check+battery It should really go onto a battery minder all winter.
11/16/2020 8:55:45 PM • Sears Garden • Answered on Nov 16, 2020
What is the hp, mph, cfm data for my Sears leaf blower/vacuum model no. 257.796351. ( trying to find a cordless model of similar power)
7 amps 120 volts - that is 840 watts or a bit over 1 horsepower and from that is claimed the (optimistic) performance of 450 cubic feet per minute and an air speed of 260 mph. I advise a large pinch of salt with those specs as a 12 amp (nearly 2 horsepower) model claims a more reasonable 200 mph and 410 cfm. I doubt you will find a cordless model to match the performance of a corded type though if one is available it would probably have a short runtime from a fairly large battery.
10/21/2020 5:34:58 PM • Sears Garden • Answered on Oct 21, 2020
Need owners/operating manual for a Sears model 917.60051 chainsaw!
SearsPartsDirect.com can help you with that
6/18/2020 3:05:10 AM • Sears Garden • Answered on Jun 18, 2020
2answers
I have a honda 3813 riding mower. When i try to start it,it backfires a litttle but will not run.?
Backfire usually means that it is out of time. This sometimes happens when something is hit causing the flywheel to jerk shearing the flywheel key. Remove flywheel and replace woodriff or slot key.
5/10/2020 5:00:42 PM • Sears Garden • Answered on May 10, 2020
I purchased a weiderpro 6900 from Sears and missing pulleys.. number 48 on page 13 of the user's manual to be exact.. Sears has no idea when (if ever) I will receive these pulleys...
https://www.searspartsdirect.com/model/9nkf19axep-001490/weider-831149220-weight-system-parts?page=2
1/28/2020 8:39:03 PM • Sears Garden • Answered on Jan 28, 2020
I have a sears Chraftsman 1 1/2hp router model 315.17432 I need the electrical hook up diagram. for the switch assembly?
You can buy another one for $25.00--$300.00 on eBay. I had the same model once, did not last very long and the parts were more than the thing was worth. I tossed it and bought a Dewalt and there is no comparison the Dewalt quality exceeds the craftsman, has more power and runs smoothly. I do not buy any tool made in china. Craftsman 315 175 Owner Manual Assembly View
10/26/2019 7:54:50 PM • Sears Garden • Answered on Oct 26, 2019
I have a sears tractor modle 917.276081 will a sears snowblower modle 486.248460 work on it
you can cross reference the model numbers on sears.com
10/11/2019 5:42:10 PM • Sears Garden • Answered on Oct 11, 2019
How do i replace the primer bulb on a sears model number 358.971170?
Go to SearsPartsDirect they will help
7/20/2019 12:15:24 AM • Sears Garden • Answered on Jul 20, 2019
I NEED A MANUAL FOR MY 2002 SEARS SNOWBLOWER MODEL # C950-52113-1
Try Replacement parts.com
7/20/2019 12:13:52 AM • Sears Garden • Answered on Jul 20, 2019
Trying to find manual for 19.5 sears craftman lawn tractor model 944.600891 . serial 020800d001043 can you help me thanks allan
Have you tried manualsonline.com? Or the manufacturers?
7/11/2019 7:35:30 PM • Sears Garden • Answered on Jul 11, 2019
Sears 25 cc Gas Blower Logo
2 questions posted
Top Sears Garden Experts
john h
ADMIN Andrew
ADMIN Andrew
CJ Rock
CJ Rock
Are you a Sears Garden Expert? Answer questions, earn points and help others
View Most Popular
Sears Garden
  • Sears Garden
Most Popular Question
sears leaf blower 358 794762 will not
  • Garden
