20 Most Recent
HP Compaq Business nc8000 Notebook Questions & Answers
My device manager always show
Hi!
To fix this, you have to download and install the Chipset and Ethernet Drivers, which can be downloaded from the following link from HP Official Support: -
Compaq nc8000 DriversVisit the above link. Click the Network Drivers link and download the drivers for ethernet (LAN) according to the LAN you have on your laptop. (you may try other Broadcom or Intel LAN Drivers)
Also, from Operating System enhancement section you can get the chipset drivers
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
5/31/2011 9:51:10 AM •
HP Compaq...
Answered
on May 31, 2011
My HP Compaq nc8000 will
Check it is powering laptop,if not the jack has bad connection and not connecting to mainboard constantly,
Dobt thats what is happening in your case but need to rule it out for next step.
Remove the battery then try ac adaptor on its own.
Next try removing ram,insert one stick only,next sub it with other stick only,if still no good remove hard drive,you are attempting to get bios start screen to show up,if still no good you may be looking at mainboard power regulator ic fails,which are a real problem on some compaq models this also damages other components on the mainboard(google search will reveal what im on about)
Dont remember offhand but if its the type that has common mainboard fail its not worth repairing as the new boards always fail eventually due to same problem.
There are also light error codes in the back of the manual and available online to diagnose this by the type of lights showing up.
2/17/2011 5:40:36 PM •
HP Compaq...
Answered
on Feb 17, 2011
The screen on my HP
The culprit will be the inverter board of your LCD screen that drives the backlight, my nc8000 shows the same symptoms after 6 years of heavy daily usage. After pressing the LID sensing button near the right hinge the backlight usually remains on, but sometimes you have to press it several times under a minute once it finally stays on. The proper fix would be to disassemble the screen and replace the inverter board, as the LCD and the CCFL backlight tubes are perfectly fine in my case.
On how to remove the screen from the laptop, you can get help from this HP guide:
http://bizsupport.austin.hp.com/bc/docs/support/SupportManual/c00803690/c00803690.pdf
(it's in section 5-35, that starts on page 128)
Unfortunately, I can't help you out on the other part, on how to disassemble the screen itself (but I suspect it has 4 or 6 screws under the rubber "feets" on its front), and I can't help you out in fixing the inverter board itself either...
If you want to fix the board yourself, you have to be able to wield the soldering iron perfectly, and your goal will be to replace some capacitors (they are usually bulging, so you can identify them being the culprit by the naked eye too).
The other option is to order a replacement inverter board, and simply swap the bad with the new one, it is still more economical than to buy a new display assembly as a whole; some chinese manufacturers are available, but I bet you can find some source more closely to your current location, just google for:
hp nc8000 inverter board
10/18/2010 1:50:08 PM •
HP Compaq...
Answered
on Oct 18, 2010
I have a problem getting
In that case it was corrupted. The easiest and fastest way is to reinstall - a only 2 hour fully automated process.
9/15/2010 6:33:05 AM •
HP Compaq...
Answered
on Sep 15, 2010
Dell Latitude D500. Blue Screen.
This is directly from Dell, please follow the steps below & teh resolution is guaranteed ...
» Blue Screen Errors
A blue screen error appears when Microsoft® Windows® encounters a system error. When this happens, a blue screen displays information about the specific type of error (
Figure 1).
Figure 1: Blue Screen Error
Note:
Sometimes the computer automatically restarts after displaying the blue screen.
Because so many different problems can cause a blue screen error, Dell recommends using the Blue Screen Wizard to guide you and help narrow down the possible causes:
- refer to Dell Troubleshooting Wizard : "Troubleshooting Blue Screen Error Messages in Microsoft® Windows® XP" Wizard ID: 168551.
- From the drop-down menus, select your
- Operating System
and
- Computer Type
- Follow the Wizard's troubleshooting instructions.
Fame !
8/9/2010 6:49:47 PM •
HP Compaq...
Answered
on Aug 09, 2010
Hi, everyone.. I need help
For what you have said earlier the main problem for making system to trip off in a second or minute timing is because of the Processor fan that stops working even if you have a bad resistors or so that might have be burnt or whatsoever fault, once you make use of your full charged battery it suppose to last you very well on your laptop but the main problem and the solution am to render is just for you to get a replacement for your processor fan , Whenever the processor is hot , it will trip off and shutdown in a seconds or minute timing. so the best for you is you getting a well blowing cooling fan and let the processor gets cool. The other time you try to ON it and it ON , is just because you allow it to cool for a little time thats why you have it On again but is not advisable to keep ONing it so just change the FAN and then if your charger is bad change it and then have your PC working fine. N:B Your Fan is faulty is the cause of your system tripping OFF , so change it for the proper functioning of your system.
8/5/2010 10:27:47 AM •
HP Compaq...
Answered
on Aug 05, 2010
Compaq nc8000 won't start please i wont to know
It could very likely be the motherboard causing the problem, in which case you're best off just getting a new computer rather than replacing or repairing the board, but it could also be a power issue.
Try turning the computer on with the battery installed and the AC adapter disconnected, and then try it with the AC adapter connected and the battery removed -- does it show the same symptoms both times?
6/8/2010 4:31:06 PM •
HP Compaq...
Answered
on Jun 08, 2010
Screen goes black. put it in sleep mode. then hit ...
this could be probably due to static charges or corrupt bios settings.
Turn off the PC, disconnect the AC Adapter and remove the battery. Now press and hold the power button for 45 seconds.
Now download and install the latest BIOS update available for your notebook from manufacturer's website. If issue persists, reinstall the display drivers.
I hope this will help to resolve the issue.
5/24/2010 2:14:54 PM •
HP Compaq...
Answered
on May 24, 2010
How do I tell if a HP NC8000 business laptop has a
Go to Device Manager (for example via Control Panel - System - Hardware) and look under Network Cards. If your computer has a wireless on/off switch (on the side of the laptop or above the keyboard), make sure it's in ON position.
1/11/2010 3:20:08 AM •
HP Compaq...
Answered
on Jan 11, 2010
Unmountable Boot Volume BSOD
0xED is not just specifically present on HP computers but all PC-based computers which has XP or later using NTFS on it. It can be resolved by doing a chkdsk /f /r or by performing a repair installation using windows.
This is caused by software corruption (which is repairable using the steps aforementioned) or hardware failure, which may lead to OS reinstallation or harddrive replacement
6/14/2009 6:53:38 PM •
HP Compaq...
Answered
on Jun 14, 2009
My nc8000 shuts down after few seconds and starts after power plugged in or battery inserted
Hi Turecki, It's a moderately easy fix for this common issue with HP/Compaq Laptops. Simply go to ebay, purchase an "inverter" board built for a NC8000 laptop can range from $10-$50 just purchase one with a minimum 6 month warranty. Its about a 0.5 inch by 15 inches. Unscrew all of the tiny phillips screws located and hidden behind black rubber covers on the LCD screen. Pop off the plastic LCD cover and replace the inverter board located at the bottom of the LCD (plug & play). Put it all back together and voila...problem fixed.
Have fun and practice some repair skills.
~Alex
3/7/2009 3:48:53 PM •
HP Compaq...
Answered
on Mar 07, 2009
Where do i find umlauts on hp compaq nc8000
1) Enable the Numlock.
2) Press the following combination for different umlauts.
eg : If you press 132 holding the Alt key, If will give you ä
Other key options
alt plus 132 ä
alt plus 137 ë
alt plus 148 ö
alt plus 225 ß
alt plus 129 ü
alt plus 142 ä
alt plus ë
alt plus 153 ö
alt plus 154 ü
Rate the solution as Fixya !
Rgds,
AD
2/22/2009 5:03:34 PM •
HP Compaq...
Answered
on Feb 22, 2009
I need to know how to turn on a HP X13-04657 LAPTOP, all the lights are on but nothing on the screen.
HP X13-04657, is 2007 PC THOSE this PC has CCFL back lamp strip that is dead.Vista era PC, laptops. are hard to work with now, 17 years old.is this not a HP COMPAQ presario HP X13-04657 (wrong name!) sorry !became HP in 2002. so is HP but manuals are super hard to find now. that x13 is part of the microsoft license code vista. (so is distraction to what it is)the real name of the Laptop is and was Presario CQ61 laptop CQ61 the PC has bottom sticker that shows the real names of PCs.CQ61-219TU is real name of on CQ61, there area many different sub codes, and they are not all the same.CQ61-306AX this had CCFL (cold cathode florecent lamps) that love to fail 3 waysdead, blinks ,dime or yellow = white.was made until 2009 and evolved, to LED backlamps.-410 is CCFLI will answer for CCFL as those just love to fail,but the the test is so easynow the answer for ANY laptop this old. 2007 and older. black screen all the time, and BIOS screens dead, answers only me. here. remove the main battery (large) it simply snaps off the bottom.the power pack is next we run the PC on your power pack AC to DC it must make the screen glow with something, do not use the wrong pack as in mixed up with others.now the lap top seems on, even the fan blows, LED glowpoint a flash lamp at the screen ,dark' room , and of you see any kind of LCD data on the screenthe CCFL lamp below #1 is bad.this is phase 1 testing, as other things can fail too. The keyword below is Mercurythis tells me it is those pesky CCFL glow tubes. 2007 is the year some PC went to LED back lamps. yes I was correct the service manual I did find proves they made both lamp types
