No, unless you know the dosage of the hose end sprayer. Are you a CERTIFIED CONTRACTOR?
Atrazine 4L is a restricted use post-emergent and pre-emergent herbicide formulated by Drexel Chemical Company. It is used to safely control annual broadleaf and grass weeds in cornfields, sugarcane fields, and turfs. The active ingredient, Atrazine will kill weeds as seeds or kill emerged weeds through the root system. Atrazine 4L Herbicide will control for barnyard grass, chickweed, henbit, and more. Atrazine 4L Herbicide is a flexible product that can be mixed, measured, and applied in different ways to prevent unwanted vegetation from taking over crops and ornamental turfs.
Atrazine 4L is a restricted use herbicide that can only be purchased and applied by certified applicators.
It is restricted use and requires a license to purchase. Please give us a call if you need a non-restricted use herbicide recommendation.
Tools Needed
To apply Atrazine a backpack sprayer, handheld pump sprayer, hose-end sprayer or professional skid sprayer is needed.
When applying Atrazine 4L to residential lawns, a handheld pump sprayer or backpack sprayer is recommended.
The yield for Atrazine 4L Herbicide depends on the type grass or cropland the product will be applied to. For most applications, 0.6 to 0.75 ounces of Atrazine 4L will treat up to 500 square feet, and 64 ounces of Atrazine will treat up to 1 acre.
https://www.solutionsstores.com/atrazine-4l-herbicide
