20 Most Recent HP LaserJet IIIp Printer Questions & Answers
Paper jamming only takes card stock however does not print anythi
I would replace the printer if it was giving me that much trouble.
5/11/2017 2:51:07 PM • HP LaserJet IIIp... • Answered on May 11, 2017
HP IIP printer prints spaces where ink should be.
HP Print Diagnostic Utility was created to help users troubleshoot and correct many common problems on Windows-based computers that can prevent printing.Follow the on-screen instructions to run the utility. Details and specifications File name: s.gif HPPDU.exe [1/1, 1.54M] System requirements: s.gif No additional prerequisites Released: s.gif 2010-08-13 Version: s.gif 3.0.0.013 Compatibility: s.gif Microsoft Windows Vista, Microsoft Windows Vista Home Premium (32-bit), Microsoft Windows Vista Home Basic (32-bit), Microsoft Windows Vista Business (32-bit), Microsoft Windows Vista Ultimate (32-bit), Microsoft Windows 7 (32-bit), Microsoft Windows 7 Home Basic (32-bit), Microsoft Windows 7 Home Premium (32-bit), Microsoft Windows 7 Professional (32-bit), Microsoft Windows 7 Enterprise (32-bit), Microsoft Windows 7 Ultimate (32-bit), Microsoft Windows 7 Home Basic (64-bit), Microsoft Windows 7 Home Premium (64-bit), Microsoft Windows 7 Professional (64-bit), Microsoft Windows 7 Enterprise (64-bit), Microsoft Windows 7 Ultimate (64-bit), Microsoft Windows 7 (64-bit), Microsoft Windows Vista (64-bit), Microsoft Windows Vista Home Basic (64-bit), Microsoft Windows Vista Home Premium (64-bit), Microsoft Windows Vista Business (64-bit), Microsoft Windows Vista Enterprise (64-bit), Microsoft Windows Vista Enterprise (32-bit), Microsoft Windows XP Fix/Enhancement: s.gif This version of the HP Print Diagnostic Utility provides an improved user interface in multiple languages, improved diagnostic and problem resolution capability, and support for usb and network connected devices.
5/18/2016 6:35:35 AM • HP LaserJet IIIp... • Answered on May 18, 2016
Paper does not feed through, gets crumpled, jams
you have to remove all covers, then you have to clean all paper feed rollers..chek fuser assy too! If you unable to do that just go visit any special printer service!
4/10/2014 10:35:09 PM • HP LaserJet IIIp... • Answered on Apr 10, 2014
Error 52
Your 3P printer with the 52 error is going to need a scanner motor assembly.
Have somebody local look at it before you put money into this printer.
Considering its' age it just maybe looking to retire.
3/31/2011 5:26:01 AM • HP LaserJet IIIp... • Answered on Mar 31, 2011
I just got a new computer, tried to add my old
Your printer may be "trusty", but the real operative here is OLD.
The IIIp was introduced in 1991, that makes it almost 20 years old.
It isn't supported anymore. If your new computer is running Win7, you might
want to try the 'universal print drivers'. Just plug the printer in and see if
the OS picks it up.
If it doesn't, you are going to have to retire the beast.
1/28/2011 6:38:40 AM • HP LaserJet IIIp... • Answered on Jan 28, 2011
The printer is HP LaserJet III . Please - what
A 50.4 code is bad line voltage. Don't plug it in a surge protector.
Any other 50 error is a fuser problem. Turn the printer off for at least 10 minutes. Power it back on. If the error returns, replace the fuser.
10/21/2010 5:31:33 AM • HP LaserJet IIIp... • Answered on Oct 21, 2010
I need a manual for
Search here -->link.
10/6/2010 1:43:56 AM • HP LaserJet IIIp... • Answered on Oct 06, 2010
Printer feeds paper 1/3 way in as usual and then
you have to change the exit rolls, your printer is too old, but it is great
3/26/2010 11:25:55 AM • HP LaserJet IIIp... • Answered on Mar 26, 2010
LASERJET 3p pcl 5 not printing in legal us size
check the user manual to see if the printer support that kind of size or not, or it may have somthing wrong in your software setting
3/19/2010 6:23:03 PM • HP LaserJet IIIp... • Answered on Mar 19, 2010
When printing a pdf file it omits several lines
You need to select "Fit To Page" in the printer properties, Or "Scale" this is simply a page setting. The page setting is too big.
3/15/2010 10:04:15 PM • HP LaserJet IIIp... • Answered on Mar 15, 2010
Modern Printer Using HPIIIP Lotus Printer Codes?
This printer uses the first version of the HP PCL (Printer Communication Language) driver. HP is at this stage at PCL6, I am not entirely sure if it is backwards compatable.
8/5/2009 12:49:35 PM • HP LaserJet IIIp... • Answered on Aug 05, 2009
My printer does not have
not to sound like a smart A** but is the outlet you are plugging into live? also check contacts on the part of the plug that goes into the printer.
8/4/2009 4:39:19 PM • HP LaserJet IIIp... • Answered on Aug 04, 2009
HP LaserJetIIIP - just won't switch on - cable and fuse OK
I can't believe that someone is still using one of the first LaserJet printers I got certified on!!! If you really want to gut the machine, there is a fuse in the power supply that could have blown. It is also possible that the power supply has finally died on its own after all of these years. You may just want to check the output voltages first to make sure of the status. If some voltages are present and not others, the fuse is still good, but the output circuitry is shot, in which case you would need to get a replacement power supply (if they are even available anymore).
Be careful with the disassembly process. The plastic clips may be brittle after almost 2 decades and could easily snap apart.
5/29/2009 12:12:13 PM • HP LaserJet IIIp... • Answered on May 29, 2009
HP IIIp prints extra blank pages
HI there make sure that the paper tray guides are fully against the paper also try sending the job through the manual feed to see if you get the same problem. If you do not then it maybe that the paper cassette separation pad is worn and will need replacing. If your model has no rubber pad at the front of the cassette then you will have a metal hold over one corner of the paper make sure that when the paper lifts that the paper sits under the silver (Dog Ear) as this acts as a separator.
Hope this helps
Thanks J
4/16/2009 12:45:20 AM • HP LaserJet IIIp... • Answered on Apr 16, 2009
HP Laserjet IIIP starting printing thin vertical black line
Was this happening before you swapped toner?
Is there toner streaks on the drum? Yes? Defective.
What if you stop the printer (open cover) as it passes through the fuser to determine if image is from drum or fuser?
But really....isn't it time to move on anyway???
3/21/2009 7:07:24 PM • HP LaserJet IIIp... • Answered on Mar 21, 2009
10answers
Paper will not feed
There are rollers that cling on to the paper and move it through the machine. When the rollers are worn down they do not grip the paper. For a short fix you can get something rough like sandpaper, brillo pad, etc, and gently scratch the rollers to give them some traction. This will temporarily solve your problem until you can get the rollers replaced.
3/12/2009 10:01:48 PM • HP LaserJet IIIp... • Answered on Mar 12, 2009
2answers
Error 55
Error 55 (internal communication problem)
  • On the HP 2 series you have to replace both the dc controller and formatter boards. On all other printers it can be several things: DC controller, formatter, main motor
1/18/2009 11:12:35 PM • HP LaserJet IIIp... • Answered on Jan 18, 2009
55 error service
The 55 error doesn't boil down to one specific problem and most information will tell you the following: 55 ERROR (Internal Communication Problem) 1. Replace DC Controller PCA. 2. Replace Formatter PCA. 3. Replace both at same time. So sounds alot like the main board is starting into a nose dive, but seeing as that particular printer is on the older side, you might be able to find the part on the cheaper side, check out e-bay, they have some HPIII part around. Good luck.
8/29/2007 4:59:28 PM • HP LaserJet IIIp... • Answered on Aug 29, 2007
HP LaserJet Pro MFP M130fw. Error code 58.04 Laser jet pro mfp m130fw
Question edited for clarity and toss in a load of CAPS. Question moved from 'Jet Office Equipment' category. It's not good!
HP Color LaserJet Pro MFP M477
Printcopy.info https://printcopy.info > brand=HP > code=58 Code: 58.04; Display: 58.XX Error, Turn off then on; Description: The product has experienced an error with the low voltage power supply. Missing: M130fw. ‎' Show results with: M130fw.
58.04 printer display error on powerup
HP Support Community https://h30434.www3.hp.com > td-p Aug 2, 2018 - THE ERROR CODE PROBLEM OF MOTOR POWERSUPPLY BOARD (SMALL DAUGHTER BOARD TOP OF THE SCANNER UNIT), Transistor no of 905,903 like ..before you change check motor ... My printer is displaying, "58.04 Error power outage detected... Jun 28, 2022 Laserjet Pro 400 MFP 451dn error message 58.04 Aug 5, 2013 My laser jet MFP M477fdw printer is showing 58.04 error cont... Sep 22, 2021 HP M451 Error 58.04 - HP Support Community - 5830295 Nov 1, 2016 More results from h30434.www3.hp.com Missing: M130fw. ‎' Show results with: M130fw.
Error Codes > HP > LaserJet Pro MFP M130 > Code 58.XX
Printcopy.info https://printcopy.info > brand=HP > code=58 Code: 58.XX; Description: The product has experienced an error with the low voltage power supply. • 58.04 = Low voltage power supply malfunction; Remedy: 1. ..
1/13/2024 5:59:42 AM • HP LaserJet... • Answered on Jan 13, 2024
HP LaserJet IIIp Printer Logo
25 questions posted
k24674
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
LaserJet HP
  • LaserJet HP
Most Popular Question
just got new computer tried add old
  • Office Equipment & Supplies
