20 Most Recent
Rival Steam Wave Iron Questions & Answers
How do you turn on a rival steam wave iron
The Manual for the Rival IR699 and IR999 Steam Wave Iron may be downloaded in PDF from the following link:
http://www.rivalproducts.com/manuals/MANUALS/IR999_43_64403016.PDFSTEAM IRONING1. Fill the Water Reservoir.2. Plug the cord into a 120-Volt AC outlet.3. Select the fabric setting you desire using the dial. Allow the iron toheat for 2 minutes. While the iron is heating, make sure it is sitting onits heel rest on a stable, protected surface.4. Turn the Steam Selector to the appropriate setting. Begin Ironing.IMPORTANT: When not ironing, always set the Variable Steam Selectorto (Dry) and the Fabric Select Dial to OFF.
I need a temperature control plug for Rival 12 " electric skillet GRS 120 W/SY-101k
You can usually find a manual for an appliance like a Sunbeam Vegas electric pressure cooker on the manufacturer's website. If you have the model number, you can search for "Sunbeam Vegas electric pressure cooker model X manual" and see if the manufacturer has made it available online. If you are unable to find it online, you may be able to contact Sunbeam customer service and request a manual.
Where do I get parts for the rival deep fryer model CZF625? The plastic handle internal plastic parts fell apart, probably from the heat.
Direct from Rival, plus some on Amazon.
Rival Deep Fryer Replacement Parts ' Deepfryeri
https://rival.deepfryeri.com > Rival
We pared 8 distinguished rival deep fryer replacement parts features over the last 3 years. Check out which ... Filter by model, type, country region of manufacture and color. ... Rival Electric Deep Fryer czf625 Replacement Air Filter Cove. (4) ...
Parts for rival fryer czf625 - Fixya
https://www.fixya.com > ... > Kitchen Appliances - Others
Feb. 4, 2014 - I have a Rival CF-250 cool touch deep fryer. Where do I get the magnetic breakaway power cord, filters, and filter cover. Please let me know.
Rival CZF625 Deep Fryer Troubleshooting Help & Support ...
Sep. 27, 2009
Owners manual for Rival CZF625 deep fryer - Fixya
Jan. 13, 2013
SOLVED: Need to find a replacement basket - Fixya
May 26, 2007
SOLVED: Need a power cord CZF625 - Fixya
Aug. 31, 2009
More results from www.fixya.com
Rival - Replacement Parts / Deep Fryer Parts ... - Amazon.com
https://www.amazon.com > Replacement-Parts-Rival-De...
Online shopping from a great selection at Home & Kitchen Store.
Gadgets vs107 top and bottom rival seal a meal
ind helpful customer reviews and review ratings for Seal-A-Meal VS107 ... Also, you don't have to search for Rival bags..any 5-mil vacuum seal bag will ... Two things, you have to get the top of the bag straight and flat for it to make the seal. ... I checked out lots of different brands before deciding to buy this lower cost model.
Gasket rival vs107 top and bottom
Bag will not seal
• Check that there aren't any gaps, folds, wrinkles or holes in pre-sealed edges.
• Moisture of foods with high liquid content will prevent the bag from
sealing properly. Cut bag open and wipe top inside of bag and reseal.
• Make sure you've placed the bag in the proper place. When making a
bag from a roll, make sure end of cut piece is on Sealing Strip, NOT over
Lower Sealing Gasket or in Drip Tray.
• Make sure you give the appliance time to cool down. Wait at least 20
seconds between seals.
If all the above have been verified and the machine will still not pull a vacuum, you will need to replace the upper and lower gaskets.
