20 Most Recent HP DesignJet 500ps (42 in.) InkJet Printer Questions & Answers
How do you change the print head on anHP designjet
there should be a second door that allows you to get in there and do it. Or you will find a menu selection to change printhead.
3/30/2021 9:29:56 AM • HP DesignJet... • Answered on Mar 30, 2021
System error 80:01
System Error: 81:01Description:Paper-Axis shutdown.Corrective Action: If this error code appeared but was NOT caused by a paper jam, then try the following:Perform the Paper Advance Test.Replace the Encoder Disk Assembly
3/28/2021 9:00:47 AM • HP DesignJet... • Answered on Mar 28, 2021
Error 81-01 on hp designjet 500+ new drive
Error indicates paper axiss shutdown. go to service mode & test paper advance test,observe drive roller rotating? at least jerking?. if its jerking remove the motor, rotate manually observe friction of drive roller if its too friction find the fault, apply grease for free movement. once completed do service test for paper axis motor. Note: only professionals can do this activity..
3/28/2021 8:59:48 AM • HP DesignJet... • Answered on Mar 28, 2021
SYSTEM ERROR SEVERE ERROR 0X9010001 TASK :
System Error is 81:01 if it is a DNJ 500ps. Go to this link for troubleshooting information:http://h30499.www3.hp.com/hpeb/attachments/hpeb/bsc-414/51634/1/50081.pdf
3/28/2021 8:58:34 AM • HP DesignJet... • Answered on Mar 28, 2021
Plotter show s system error
This is a firmware error, you need to go to www.hp.com, then support, firmware & drivers, follow instructions. At the bottom of the drivers you will find firmware. Make sure your machine is pluged in and switched on, download the firmware and simply follow instructions, this should solve your problem.
3/28/2021 8:55:16 AM • HP DesignJet... • Answered on Mar 28, 2021
2answers
Cannot turn the printer off from the swcth
I am getting the same error message. Did you ever get it fixed? If so, what did you do?
3/28/2021 8:39:30 AM • HP DesignJet... • Answered on Mar 28, 2021
Replacement carriage belt for HP DesignJet 800 Printer
It is not recommended that the user replace the carriage belt, on any HP printer. Any damage caused by the user, won't be covered by the warranty and will likely result in a completely useless, but very expensive doorstop. Or paperweight..
I do believe your printer has since been discontinued for support, however only an HP Customer Service Representative would be able to confirm that. I would suggest phoning HP for technical support or to at least confirm whether support is available.
Even if your printer is no longer a) under warranty, which I suspect it's not, or b) out of support completely, they may be able to provide you with a list of Authorized Service Providers (ASPs) within your area.
1-800-474-6836
Best Of Luck.
3/28/2021 8:37:56 AM • HP DesignJet... • Answered on Mar 28, 2021
2answers
Help with printing to HP Design Jet 500ps from a PDF!
I have had some success by converting pdf to jpg and printing from Adobe Photoshop. The HP 500 ps and 500plus are VERY fussy about paper size conflicts.
11/22/2017 9:16:42 PM • HP DesignJet... • Answered on Nov 22, 2017
Hp 500ps severe error code Ox40d0003-
If any of the troubleshooting steps listed below solve the problem, attempt to verify printer functionality (instructions listed below). If functionality is verified, no additional parts should be replaced.
    NOTE: Always verify the printer's current Firmware release and upgrade as needed.
    1. Turn the printer off, then on to verify error. If no error attempt to verify functionality.
    2. If the error appears or problems persist, continue with the remaining steps.
    3. Turn the printer off, and disconnect the power cable.
    4. Remove the right end cover.
    5. Check both Ink Supply Station connections on the Interconnect PCA. If the unit shows the error on boot up verify that the connector with the blue wires is seated correctly (Connector P4). If the error appears when a print job is sent to it verify that the connector with the red, black and green wires is seated correctly (Connector P2).
    6. Reconnect the power cable and turn the printer on.
    7. If no error appears, attempt to verify functionality.
    8. If the problem persists, continue with the remaining steps.
    9. Replace the Ink Supply Station (refer to pg. 8-48 of the HP Designjet 500 and 800 Series Service Manual).
    10. Following replacement, attempt to verify functionality.
    11. If the error reappears, replace the Electronics module (refer to pg. 8-24 of the HP Designjet 500 and 800 Series Service Manual).
1/6/2017 4:19:03 AM • HP DesignJet... • Answered on Jan 06, 2017
Error lift blue lever
At what point does the error occur?
6/16/2016 10:28:22 PM • HP DesignJet... • Answered on Jun 16, 2016
2answers
Lift blue error
Typically the lift blue lever error comes up if the plotter detects skew when loading paper. If the paper cannot be loaded without skew then either you do not have the roll seated on the holder properly or the roll of paper was not made properly, which I have seen.
2/18/2016 7:26:25 PM • HP DesignJet... • Answered on Feb 18, 2016
I have problem with plotter
A 79 error most often indicates that you have a problem with the firmware for the printer. Go here and download the firmware update that corresponds to the operating system that you have installed on the computer. Follow the directions that download with the file and you should be printing again.
11/25/2015 8:52:37 AM • HP DesignJet... • Answered on Nov 25, 2015
When giving a print command there is an error message 79.04 showing power-off
you need make firmware Update download firmware from HP.com 79.04 generic error for firmware
3/13/2015 9:57:21 AM • HP DesignJet... • Answered on Mar 13, 2015
Replace the Encoder Disk Assembly.
Replace encoder disk sensnor many times disk are good and sensor are damaged! try clean it first
5/13/2014 6:04:40 AM • HP DesignJet... • Answered on May 13, 2014
2answers
Message d'erreur code 11:11
Error code indicating that Trailing cable faulty, replace it. But technical skills required to replace this spare..12_15_2011_10_37_11_am.jpg
5/13/2014 6:03:06 AM • HP DesignJet... • Answered on May 13, 2014
81 01 error
Paper-Axis shutdown - usually a paper-jam caused by a blockage of the Paper-axis System. Action- Try the following= If this error code was caused by a paper-jam, unplug the power cable from the printer and clear the blockage. Plug in the power cable again and check if the Error Code has disappeared -If this error code appeared but was NOT caused by a paper jam, replace the Paper-Axis Motor Drive Assembly
4/26/2014 2:41:35 PM • HP DesignJet... • Answered on Apr 26, 2014
HP DesignJet 500ps (42 in.) InkJet Printer Logo
103 questions posted
k24674
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
DesignJet HP
  • DesignJet HP
Most Popular Question
message derreur code 11 11
  • Office Equipment & Supplies
