20 Most Recent
HP DesignJet 750c plus InkJet Printer Questions & Answers
I am getting an 060309 error code on a HP
Probable cause:
The optical sensor on the carriage has
failed to locate lines drawn during the
pen calibration routine. Reduce the
ambient light. If the media is not clean
and reflective, change the media. If
the lines are faint, replace the pens.
Clean lenses. Replace LED. Use the
Edge detect test, found in the service
menu, to help troubleshoot.
Cannot find driver for my
There are free software you can download for this designjet 750c by finding at websearch like yahoo.com or msn.com. Just type the driver name for this printer and you can download it for free. Most of the printer driver now can be downloaded online with free cd key. Just let it try. or Maybe the printer you are installing is not compatible with windows 7. try to read you printer's user manual.
HP 750c+ plotter not responding
turn and unplug for 30 secs then open and remove / re-install each ink barrel according to your manual. You will have to go through the ink installation on your keypad one by one.
Error 010032 00070b18
SYSTEM ERROR 010060 is a Primer Motor sensor problem, Sensor might be bad, motor might not be turning, cable could have failed, or main PCA might be bad.
070020 Is a drop detect sensor error, the sensor is part of the service station.
The check cartridge path indicates that the carriage rails need lubrication, use a light silicone or synthetic lubricant, (it could be other things, but this is the most likely), you also might need to replace the belt.Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
HP Support
System error code 070010
07-00-10 error code refers to a drop out voltage warning,
basically this means something in the machine is shorting the power supply out,
the chance's are that the fault lies with the trailing cable where the laquer and white coating eventually wears down to reveal bare trailing cable connections which short to ground causing the power supply to temporarily shut down causing the formatter to display the error.
this is a very old model now and the chances of you being abble to order 'new' have allready gone. I would recommend upgrading to a newer model.
Leave in cartridges?
yeah of course.. Remove print cartridge from printer and place air tight bag or polothin..
Leave in cartridges ?
You don`t need to remove cartridges, just don`t forget to print something at least once a month, to prevent nozzles dry up.
