20 Most Recent HP LaserJet 4100 Printer Questions & Answers
HP 4100 printer SHOWING 'cold reset'
FIRST Turn the printer on. Watch the control panel. When the memory starts counting, press and hold the green (Select) button. ... Release the (Select) button. The control panel will display SELECT LANGUAGE. Press (Down Arrow) button until control panel displays COLD RESET. Press (Select).
7/25/2021 10:24:16 AM • HP LaserJet 4100... • Answered on Jul 25, 2021
Why does it keep replacing random characters with a T from a Word doc?
Use PCL 5e driver (or the one without PCL6).
11/2/2017 6:08:40 PM • HP LaserJet 4100... • Answered on Nov 02, 2017
Pcl xl error subsystem: Kernel error: MissingAttribute Operator: BeginPage Position: 3
Contact HP Printer Support Teams Call.... HP Printer Support Thanks,
7/1/2016 12:19:34 PM • HP LaserJet 4100... • Answered on Jul 01, 2016
HP LaserJet 4100 for all applications in windows 7. When I go to print a document and click on print. The print screen exits, the print job doesn't processes, and the print queue stays empty. Noth
I have Windows 7 and I found that running troubleshoot on the printer works most of the time and keeps me from having to shut everything down. Go to
  • Control Panel>Hardware and Sound>Devices and Printers
  • In the upper left of the window select File
  • In the drop down list select Troubleshoot
This usually fixes the problem, really empties the printer queue, and I don't have to shut everything down.
1/27/2015 5:23:00 AM • HP LaserJet 4100... • Answered on Jan 27, 2015
2answers
Laserjet 4100 Has an annoying beep on print. How do I disable it?
The plug needs to be into the wall outlet. If it is in a surge protector, the electric flow can be interrupted and cause the beep.
11/27/2014 6:34:00 PM • HP LaserJet 4100... • Answered on Nov 27, 2014
What would cause paper jams in a hp 4100 printer
Where is it jamming. Printer this age could have fuser issues, worn rollers that are not picking up properly. Is the jammed paper crinkled up or does the printer stop before damaging the paper? If paper is not damaged, the cause is usually in the paper pickup slipping and causing the printer to think that the paper is either too long or too short. Clean all the rollers in the paper tray cavity with a damp cloth.
9/6/2014 5:11:15 AM • HP LaserJet 4100... • Answered on Sep 06, 2014
0answers
0answers
2answers
REPLACE toner cartridge
See the illustrated instructions beginning on page 88 of http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/bpl10335/bpl10335.pdf for removing and reinstalling the toner cartridge.
12/29/2013 2:22:05 AM • HP LaserJet 4100... • Answered on Dec 29, 2013
My HP LaserJet 4100 is having a misalignment
check configuration page for paper size in tray 2. It is taken from sensors on tray - make sure it is set correctly
11/2/2013 1:22:56 AM • HP LaserJet 4100... • Answered on Nov 02, 2013
2answers
My printer shows 41.2 errors
Hope it helps
1. A temporary printing error has occurred.
2. Press GO. The page containing the error will automatically be reprinted.
3. Reseat the connections to the laser scanner and then to the engine controller board.
4. Replace the laser scanner.
5. Replace the engine controller board.
2/27/2013 10:28:54 PM • HP LaserJet 4100... • Answered on Feb 27, 2013
HP LaserJet 4100 Printer Logo
99 questions posted
k24674
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
LaserJet HP
  • LaserJet HP
Most Popular Question
hp laserjet 4100 all applications in
  • Office Equipment & Supplies
