20 Most Recent
HP DeskJet 612c InkJet Printer Questions & Answers
My printer keeps flashing the yellow trouble
Turn it off, put a few drops of oil (3 in 1 or sewing machine oil) onto the bar that the carrier rides on, if you can move the carrier to the left and put some oil (just a few drops) on the right side also.
The top portion of the text in each line is not
1. Shake ink cartriage and Re-clean the print head, dripping alcohol to drain off and wipe clean w/tissue (do not touch with fingers).
2. Apply slight suction to print head to clear clogged ink (if by mouth, spit out ink and water rinse etc.).
3. Re-clean per step 1
4. Insert ink cartiriage, seating it all the way into holder.
5. Run a "cleaner sheet" through printer to clean al printing parts
("cleaner sheets" are available at office supply stores).
6. Printer should print all parts of letters.
When I try to print,
hi.... First check the lifter *** lifting the tray, when the caridge block move towards the left it pushes the plastic lock of lifter assembly to lift the tray check them for working if it works then go to next step..
clean the feed roolers & replace the paper seprator of the printor satuated on the end of paper feed tray (brown colour).
Your problem will be resolved 100%.
Hp612c deskjet printer attempts to feed paper, but
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you.
Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
DOES NOT PRINT AT ALL
There is a rubber feed roller above the paper. Clean this roller with WD40. Do not spray the roller. Spray a small area on a cotton rag and rub it all over the rubber roller. That will do the trick.
Document is sent to printer but then says
Try This :
Unplug the USB cable;
Restart the computer;
Go to the printer and faxes folder from control panel and check if there any documents is showing pending;
If still its there right click on it and click on "Cancel all pages"
Then if it shows deleting Restart the computer;
Then put the CD in the computer ;
Goto My computer- Right click on Black HP logo - Click on Explore - Open UTIL (Folder)- Open CCC (Folder)- Double Click on UNINSTALLATION L1 file;
It will uninstall the basic driver of the printer;
Reinstall the printer the issue will be resolved
Regards
Soumajit
Hp deskjet constantly says out of paper. As far
Each printer has a sensor that determines when there is no paper, on cheaper printers like deskjets it tries to feed the paper and when it fials it gives this error. The feeder for the printer is most likley bad, replcaement is the most cost effective solution , repairing it would be more then a new unit.
Printer not printing
maybe you have set the printer to a wrong port. recheck port address or reinstall printer driver.
Blinking Resume Light
i think the problem is that the printer could not initialized the printer head position. you can open the cover and turn on the printer. check if the motor for feeding paper moves but the roller does not. replace the gear attached to the roller. i hope this will help.
My Printer Is Driving Me Crazy
Hi, this sound like a driver problem. But then again, it might also be printer cable if you are using the parallel port.
I will assume the you are using WinXP and the printer is using parallel or LPT1.
Try first to reinstall the driver. The first step would be to download the latest driver for your printer at http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=58123&lc=en&cc=us&dlc=en&lang=en&cc=us. Drivers are OS specific so you have to choose what is appropriate. Switch off/disconnect your printer from your PC. After downloading, remove/delete your old 612c printer (+ drivers). To do this, start, printers & faxes, delete 612c icon. Windows may or may not ask you to also remove related software such as drivers. If asked, answer yes (this is to make sure to your fresh). Reboot (though not necessary but make sure printer is still off/disconnected).
Install newly downloaded driver. If it is in a zip file, uncompress in a temporary folder. If it is an executablwe, doublie click. Run the full install, when asked to search for a printer, decline, it will auto install in lpt1.
Soon as finished, it may or may not ask you to reboot.
Connect and power on your printer. Windows may auto detect new hardware, click cancel. Go to your printer settings and print a test page.
Hope this works for you. Good luck.
